billyboy's Avatar
carpet install
I am installing an RS carpet kit right now. While I come inside to take a break from the fumes I thought that I would mention a way to make clean bolt holes through the carpet for things like gear shift housing bolts and seatbelt bolts etc. I get the carpet glued in place and then feel through it for the underlying hole. A good hot woodburner/soldering iron pushed into the hole works nice. You can also seal the edges of cut out holes this way. If you know this, please disregard.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 01-08-2005, 11:40 AM
