What size engine lid grill? Are there two sizes?
I just bought a used ducktail for my SC. Upon installation of the grill, I discovered that my existing plastic grill from both my standard engine lid and my 1976 Turbo tail are just a bit too large to fit the duck tail properly. It rests on top of the duck tail instead if resting into it. The length of the plastic grill is just a bit too short but the width is too wide and is the main reason it rests on top of the tail. Do I need one of those early metal grills? Are they a different size?
I can post photos later. Many thanks, |
As you have discovered the ducktail is made for the smaller aluminum grill. You can use the plastic grill, but you will have to trim it to fit.
I hear that the Al grill can be a little too long to fit aftermarket ducktails too. Trim away or make your own.
| All times are GMT -8. The time now is 07:52 AM. |
