What are the symptons of a faulty WUR?
Trying to nail down a small problem that occured during cold running. It idels fine once at operating temp. But during cold temps around town stop and go the idel is low and a little rough around 300 or 400 rpms. Is this a potential WUR problem?
Thank you Moke81 1981SC |
Moke,
A search will yield a google of information. You may want to look here as well, especially under the Troubleshooting info..... http://members.rennlist.com/jimwms/CIS/CIShome.html Good luck.
Warren & Ron, may you rest in Peace. |
Designer King
Moke,
I think you are on the right track. You may be able to adjust your WUR back into spec if that is what's wrong. Besides searching WUR, also check out the AAR and AAV.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Get a book on Bosch FI (or factory manuals or the Bentley) and get a set of gauges for bosch or modify one that is not. You can tell alot by knowing the fuel pressures.
There is a bunch of stuff you can try for free. 12V at the WUR and the AAR? Remove the AAR and put 12v to it and make sure it closes. Check the decel valve by taking it out of the system. Check fuel pump output Like Paul said probably a fuel pressure issue (WUR) with the low idle but it seems like a vacuum leak in the wrong place might make a low idle too?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I'm sure I know what they are but the abbrv. I don't know. What is the AAR and AAV
Thank you Moke |
Auxilary Air Regulator and Valve.
Thanks Rick, I looked it up in the Bentley and found them. Great Book.
Moke81 |
check your pm's. i got gauges you can borrow. (unless you are not trustworthy
poof! gone |
Once you understand how CIS works and know the pressure and voltage testing procedures there is not a CIS that you can't diagnose and fix yourself. |
Vash, check your pm
