front seal
Just replaced the front main seal in an '82 sc. Only one potential problem. When you look into the top notch, the ribs of the seal got bunched up some (couple are touching and the others are wavy). Do I need to start anew??
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 01-06-2005, 07:33 PM
This has happened to a small extent on both seals I've ever installed. I left them alone and they were fine. For some reason the rubber around the edge of the seal likes to "hang up" in the notch. You'll have to be the judge as to how bad the seal looks.
-Andy
Old 01-06-2005, 08:12 PM
Bump
Old 01-07-2005, 06:40 PM
bump again. No one else has an opinion??
Old 01-08-2005, 05:04 PM
