-   -   Engine lid hinge ? (http://forums.pelicanparts.com/porsche-911-technical-forum/200674-engine-lid-hinge.html)
ecm911 01-09-2005 01:09 PM
Engine lid hinge ?
I purchased a car ( 78 SC) without the engine lid. Now trying to mount one and have a problem. Can not figure out how the hinges are mounted to the body. What type of fastener is used to attach the hinge to the body?
I have no PET cd and can not seem to find a picture any where?
earl
PS part numbers would be appreciated.
Jim Sims 01-09-2005 03:42 PM
Bolt (special), 6 mm PN: 901.512.471.20
Washer, 6mm (6.4 mm ID) PN: N0116667
Nut, 6 mm locking (nylon insert) PN: 900.910.023.02
Head of bolt is on outside; see below image. Cheers, Jim
http://forums.pelicanparts.com/uploa...1105314109.jpg
ecm911 01-09-2005 04:39 PM
Jim - Thanks soo much!!!!
WMichelsen 08-23-2024 05:16 PM
My engine lid hinges have a good bit of wobble.
Typically, when these wear out, is it the bolt/pin? Or, is it the hinge/sleeve? Or, both?
Can they be tightened up? Or is it replacement time?
http://forums.pelicanparts.com/uploa...1724458475.jpg
