-   -   '83 SC Throttle Linkage Adjustment Findings (http://forums.pelicanparts.com/porsche-911-technical-forum/200742-83-sc-throttle-linkage-adjustment-findings.html)
Gordo2 01-09-2005 07:12 PM
I recently installed a Rennline floorboard on the driver's side. I immediately noticed that with the new floorboard I wasn't getting full throttle when floored.
Decided to adjust this evening and found not only was the linkage in need of adjustment but I was missing some of the linkage bushings.
http://forums.pelicanparts.com/uploa...1105326701.jpg
Adjusting the linkage is a good quick winter project and not very complicated. Highly recommended if you haven't looked into it before. I think I wasn't at WOT prior to the floorboard change, should be interesting once I get some new bushings and everything back together.
Gordo
