Advice needed to fix SC turn signals
Well, my turn signals failed tonight. Worked at the beginning of the drive, then stopped. I haven't checked the fuses yet (I promise to first thing in the morning). Assuming that it's not the fuses, how can I know if it is a relay or switch problem?
If it is the flasher (relay)...generally the emergency flashers also do not work.
| All times are GMT -8. The time now is 10:25 PM. |
