'87 Clutch Reluctant to Disengage
The car is back from the shop where new engine and transmission mounts were installed and a transmission seal replaced.
On the drive home I noticed that the clutch is still slightly engaged with the pedal to the floor (the car will pull forward slightly) and that the pedal returns to a position about two inches below "normal".
This sounds like it should be something obvious.
Gurus, your pronouncements please.......
Old 01-10-2005, 09:19 PM
Don Plumley's Avatar
Not a guru, but sounds like air in the hydraulics.
My '87 has an intermittent "hang" on decel in 1st. Mech thought it could be rust on the pressure plate. I've re-bled the thing a bunch, and am thinking of replacing the clutch and slave cylinder.
Don Plumley
M235i
Old 01-10-2005, 09:48 PM
don911's Avatar
Air in the line would be my guess as well.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 01-10-2005, 10:05 PM
