Torsion tube question
Is this anything to worry about? I looks like a bracket.The body around the tube looks fine. This is from a 80 SC.
Ron G,
I would not waste any time getting that replaced. You are fortunate to have a galvinized chassis so your torsion tube is likely fine. I would pull the spring plate off and inspect however. Time for a little mantainance expence. Good luck. |
Get a new one! Replace the bushings with Elephant racing's or the Neatrix while your at it.
Warren Hall Student
You see that rubber thing inside the hole in the bracket. That's your springplate bushing. The bracket is the bearing surface!!!
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Your torsion tube may be fine but this springplate cover is NOT....and is a related structural member . Get it replaced pronto....faitlu cheap too, as I recall.
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
