andycook's Avatar
Help me out guys! Color Choice?
Just me again...
My car will undergo a full re-spray in the spring and I would like some input from the board. It is a 78 SC with cup style wheels on it. The original color is an orangish red, not Guards Red, but not totally orange either. Paint was ruined by being stored with a cheap car cover on it. Moisture spots over the hood and roof.
My color choices for the spray will be using the original color again, or going black. The car will be getting graphics as well following the re-spray, I just haven't figured out what exactly.
Interior is all black. New black racing seats and a four point black cage soon (getting it this weekend). Stainless and wooden steering wheel and shift knob. Any thoughts?
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
73 VW Beetle AutoStick
02 F250 4X4 (Parts Hauler)
03 Kia Sorento (Wife's DD)
Old 01-11-2005, 05:46 AM
Andrew,
Personally, I wouldn't change the color unless I was spraying a shell and totally disassembled car.
I wince when I see people "storing" their cars under a piece of plastic.
Warren & Ron, may you rest in Peace.
Old 01-11-2005, 07:36 AM
andycook's Avatar
The PO had good intentions, just didn't realize the ramifications of those cheap Tyvek type car covers. They trap moisture real bad.
So if I change color, you think I should dismantle the entire car? Makes sense.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 01-11-2005, 07:48 AM
Send a message via AIM to NoLift911
I would agree with Rick -
It always looks pretty ghetto to find different colors in the trunk/engine compartment. Everything should be fully dissassembled, stripped of any previous color and then sprayed.
No need to have useless layers of weighty paint on a shell. If you go to the trouble to take it apart, do it right.
Just my .02
-Jeff
Jeff
Old 01-11-2005, 07:58 AM
Actually Tyvek is one of the best covers to use as it breathes...at least for indoor storage. It's superior to cotton when humidity goes above certain levels. Not sure how it performs outside but I'd think it's better than a plastic tarp.
Old 01-11-2005, 08:01 AM
andycook's Avatar
The Tyvek didn't seem to work too well for this one. Trust me, I wish it had! Then again, I am not 100% sure how long it was stored like that either.
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 01-11-2005, 08:12 AM
Andy, I would stick with the original color. My car was originally Minerva Blue Mettalic and is now Guards red, done by PO. When the car was repainted, the engine compartmant and trunk were repainted, but the wheel wells and underside of the car were not. Guess where the blue is showing through now?
Chris
'80 SC
Old 01-11-2005, 10:25 AM
Bandwidth AbUser
Jim Richards's Avatar
The original orange would be my choice.
Jim R.
Old 01-11-2005, 11:01 AM
Friend of Warren
Don't give up on the original paint yet. You car did not come with a clear coat so there is a good chance you can rub out those water marks. Have you tried to do so? I've had some pretty bad looking paint that I have managed to bring back from the dead.
Kurt V
Old 01-11-2005, 11:06 AM
andycook's Avatar
Thanks guys. Kurt, no I haven't tried to rub any of it out. I figured it was clearcoated, so I didn't give it much thought. Would some good rubbing compound work or do I need some special stuff?
Andrew
Gruppe B #055
78 911SC
74 914 2.0
02 C230K Kompressor
Old 01-11-2005, 11:33 AM
Friend of Warren
Go to an auto parts store and get either a Meguiars or 3m rubbing compound that says for hand use, not machine use. Then test on one of the water spots. If it removes the water spot then you can decide if you want to do the whole car yourself or pay to have a pro do it.
Kurt V
Old 01-11-2005, 12:00 PM
If the test Kurt describes shows promise then I'd suggest having a pro do it. Unless you have experience.
Old 01-11-2005, 12:09 PM
On a great circle route
xlr8's Avatar
The PCA website has a tech section with Q&A about paint here .
An example:
"I have the white cloudy water stains from leaving a bra on too long after moisture penetrates the paint (on the whole front of the car). I have read that using denatured alcohol removes similar staining from furniture finishes. Will this work for my 911SC without damaging the paint? If not, what will work for a rather large area?
I remove white water spots on paint with Blue Magic Polish. With a moderate amount of rubbing the stains disappear. I just did this procedure on a 64 356C in front of 50 PCA members at one of our presevation seminars.
John Paterek - PCA WebSite - 3/16/2003"
Good Luck,
Russ
Old 01-11-2005, 12:27 PM
MN
Sarah's Avatar
Black
87 930 Blk/Blk
Old 01-11-2005, 12:33 PM
First, I would take it to a body/paint shop and see if they can buff out the paint for you.
I have an '86 coupe in a pastel yellow with black trim and dark tinted windows (custom paint from the factory), the drivers door was fading more than the rest of the car for some reason. Last year, I took it to "best" body/paint shop in town (recommended by the P-Dealer), they used some special compound and the result was unbelievable. The car looked new! I could not tell any difference from the drivers door to the rest of the car. Well worth the $125.00 they charged. The car looks great today and all I do is wash (by hand) and wipe dry with a coat of wax every so often. If it starts to fade again, I'll spend another $125 to bring it back to life...
Regards,
Jim
'86 Carrera Coupe
Old 01-11-2005, 12:43 PM
Shaun @ Tru6's Avatar
What is your color code? I am guessing that your car is indian red.
Tru6 Restoration & Design
Old 01-11-2005, 01:06 PM
kjb kjb is offline
kjb's Avatar
I though Indian red is what the factory called guards red until 86?
/ J
'86 coupe
Old 01-11-2005, 01:31 PM
Porsche Junky
mede8er's Avatar
I agree that if you change the color you have to stripp the car completely if you want to do it right......
1986 930 RUF equipped
Old 01-11-2005, 01:36 PM
/ J
Could very well be. When I went to paintscratch.com and typed in the code for Indian Red, it gave me 20 shades of guards red.
My targa is a more orangy version of the guards red and I think somewhat rare. I've been buying guards red replacement panels of it: fender, decklid, rear valence, side skirt and they all match, but they are more red than the res of the car.
The good part about the color is that when it's waxed, the car actually glows in the sun.
Old 01-11-2005, 01:46 PM
