porsche4me's Avatar
will paint stripper hurt the galvanizing???
I want to strip my 1977 - and I love galvanized cars !!!! after 6 914's I have a car with no rust that I can find.......and its in 16 parts for paint......
But I need to know if I should stay away from any type of stripper or is there a brand / type that is better than any other????
Thanks for the help you all are a great asset ( did I say ASSet and stripper in the same post ????)
1977 911S Coupe
Stolen - car chase - in the river - pulled out - sold to me!!!!!
"Life is running hurdles in the dark"
Old 03-03-2005, 03:02 PM
evill's Avatar
Aircraft Paint Stripper will not harm the galvanized metal, only the paint.
Sanding, grinding and most types of media blasting will damage the galvanized coating.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 03-03-2005, 05:49 PM
What Ed said.
Once done with the paint stripper use a wire cup-brush on an angle grinder to clean the surface off completely - it won't damage the galvanizing.
Regards!
Willem
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 03-04-2005, 02:23 AM
Wider is Better
wholberg's Avatar
Most paint strippers contain an organic solvent that dissolves the paint. The above posts are correct that this will not harm the galvanizing. Contact with acids would be most likely to cause damage.
Wider is Better
Old 03-04-2005, 04:27 AM
For what its worth, galvinazation is a sacrificial coating on the metal -- even under paint it rarely survives more than 10-15 years, so there's pretty good odds much of the car isn't galvanized anymore anyway.
If I was stripping a car of that age, I'd strip to bare metal and reprime with POR or a zinc-containing primer.
1968 911L
2004 Dodge Dakota SLT Plus
Old 03-04-2005, 06:38 AM
