painting the aluminum trim
How would someone paint the door frames on a mid year 911. I think there aluminum? Do you need a special paint or primer to hold onto the aluminum or something?
Thanks, David |
Have them powder coated - I did mine over a year and half ago - still look great!
Rob
________________ 78 911 SC Targa 11 Cayenne Base 15 Macan Turbo |
David, A friend of mine just did a 356 Outlaw, he also powder coated all the aluminum frames. Came out very nice. Heat required for the powder to set was around 400 degrees ? Steve, R-Gruppe #123
try anodize them.
X/A |
Any ideas for when people were just painting these type things? Cost is an issue as is time. I am not even sure who would even do this stuff around here.
These are all pieces that I can do again in the future if the paint should fall off with not much effort to remove. Is there say one primer better than another for this type stuff. Sorry, tough being on a tight budget. I am not scimping on paint supplies so these pieces will hopefully be the only things I have to attend to in the future. I had touched up parts of then in the past and they did hold up real well. Probably a temporary fix but if I can get a few years out of them great. Thanks for your help guys. David |
Still Doin Time
What color do you want to paint them??
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Aluminum is paintable, I would suggest etching them first to make the paint stick better. Scuff them up too.
Should work fine. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Etch, lightly sand with emery cloth, primer with a high quality product (Wurth, etc). Then paint to suit. They can look great (I assume you are painting them black and not yellow!).
Chris
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Acid-etch primer, available in spray cans for smaller jobs.
Oh Yeah... don't skip the above steps about oxidation removal |
Black.
Perfect, just the info I needed. Thanks everyone. |
Still Doin Time
There is 'trim black' spray paint that you can get at any auto parts store. Not shiny, not dull, very durable with a little prep.
Krylon semi-flat black is perfect. I did all my trim but snadblasted it first. Seems to be holding up fine.
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
