Wandered off somewhere...
Oil drips from Lights !!? Very strange
I had my SC sitting out in the sun yesterday for a couple hours between trips around town. The front was sitting on the apron of the garage. When I moved the car later I found two large oil spots, about 10" dia... just below both driving lights. They are pretty new Hella driving lights...not fog lamps...which have been mounted for about a month but not yet wired. The covers had been left off cuz I've lost one already. Anyway, on the bottom surface of the light housing a thin oily substance was dripping. Some small amount was also on the inside...only on the bottom and no where else on the light or anywhere else on the car. I checked repeatedly and nothing else. I place a call to Hella USA customer service and they were equally puzzled. They say no such oil is used in mfg.
Anyone ever see this before?
Mark... Porsche Boxster S 2012 Jeep Wrangler Rubicon..Crush Orange |
Designer King
Do you have oil lines or oil coolers near those lights?
How about AC? Do you have a front condenser? What about your windshield or headlight washer fluid lines?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 06-29-2005 at 02:56 PM.. |
Somewhere in the Midwest
Blinker fluid..sometimes used on driving lights to make them flicker at on coming cars. You have a leak.
![]() (JK.... that is strange. maybe your car is crying...I just can't pass this up!) |
Do not have headlight washer, windshield washer tank was just replaced and all is dry in there. I took AC out a few months ago and condenser was in the rear below the grille. Only oil line in front is the trombone cooler which is no where near these lights and this stuff is coming from both lights in about the same amounts.
This oily stuff is clean and thin, but definitely oily...not water and not motor oil. The spots on the driveway are still there today....no different. None of this stuff is anywhere but the bottom inside and out of the light housing. Like I said, Hella told me they do not use any such oil in the lights. All very strange.
Designer King
Must be light weight oil.
Or maybe it's lamp oil. Seriously, did you open up one of the lamps to check inside?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 06-29-2005 at 03:15 PM.. |
probably oil from manufacturing and/or corrosion protection liberating itself due to heat...??
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Hate to say this but, you wouldn't have a half quart of oil in the trunk under the cover near the front bumper would ya? Just a guess.
Tim 82 SC 90 C2 Yasowatt |
Tim,
Nice guess...but no. This is very thin oil and is nowhere to be found except on the bottom of the light housing...inside and out....almost gone now. My guess now is, like a previous poster said, that it is some kind of mfg. oil/finish that has gotten thinner with the heat of late. When I first noticed the oil spots...about 10" on each side...it was alarming.
Crazy thought, but what about brake lines? Maybe one is leaking and it is blowing to a low point and collecting while you are driving. It could become dark if it was sitting in a dirty area.
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Check the overflow line from the brake fluid reservoir. When the reservoir overflows, the fluid should exit from under the car about where you are describing.
The Fox Carrera |
Automotive Monomaniac
(The blinker fluid comment a few posts above is classic!)
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
The brake fluid reservoir overflow hose and the gas tank overflow should only leave a mark on the driver side. If its on both sides and directly below the headlamps, it sounds more like some kind of corrosion protection (Waxoil, Dinol, etc...) which would be a good sign.
Regards, Guenter 73.5 911T, mod |
The Fox Carrera |
the oil companies may be interested in your lights.
I deal with plastic mfr every day and there are some plastics the exude "oil" from the process over time but nothing in the quantities you are describing. I'd look for another source, brake fluid that's overflowed from your reservoir, a canister of fluid in the trunk that's leaking etc.
Dan O 84' 3.2 Targa |
Most brake fluid I've ever dealt with has a distinctive smell to it. Is it different stuff on P cars? This stuff doesn't smell like your normal brake fluid.
Is it possible another car left them there, and you didmn't notice them when parking the car? Better send this one to "unsolved Mysteries"..
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Diss Member
I assume the Hellas are halogen instead of HID...
If their was oil inside the housing the halogen bulbs would be toast. A fingerprint will take out the bulbs. Similar to the brake fluid suggestion: Any chance you have or had a spare quart of oil under the hood that is leaking?
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
D idn't E arn I t
fluid from the bumper dampers (bumper shock absorbers) is my guess....
In the movies only bad guys sleep in king size beds. |
