-   -   Glove Box Switch (http://forums.pelicanparts.com/porsche-911-technical-forum/201310-glove-box-switch.html)
js1099 01-13-2005 03:40 AM
Glove Box Switch
I am a new "poster" to this forum, but not a new reader. Recently, I purchased a low mileage 88 cab. Everything is like new with this car. I have the feeling that the glove box light switch is bad or disconnected, but have no idea how to get to it from the rear or the wires. The light works perfectly when worked manually, and there are no issues with the driver and passenger door switches. I have searched and searched and searched these forums for an answer, but to no avail. Any assistance would be greatly appreciated. :confused:
robs 01-13-2005 05:49 AM
The wires can be accessed from under the front hood (if I remember correctly).
You can try an easy fix that worked for me: push the spring loaded contact and let it snap out several times.
Wil Ferch 01-13-2005 06:06 AM
Do make sure the light switch is in the proper "position". ( always off....always on.....on/off depending on opening /closing of glove box door).
Wil
Teutonics 01-13-2005 06:08 AM
I had the same problem with mine, and it was a function of the switch mechanism in the light housing. I had to bend one of the contacts slightly to make it work properly. IIRC, the light housing just pulls straight out.
js1099 01-13-2005 06:09 AM
Wil
Thanks for the fast reply, the light is definitely in the correct position, I tried accessing the wires from the hood, but can't even see where they are. Should I remove the hoses, etc... It seems there are a few control type boxes mounted on the fender that are in the way too. Any ideas?
T-Bone911 01-13-2005 06:39 AM
Mine started to work after a WD-40 bath and snapping the spring a few times. Assuming the switch is in the proper position.
js1099 01-13-2005 06:45 AM
All excellent feedback that I will try. My last resort before buying a new switch if all these suggestions fail is to track the connection. Is this connected via one of those 2 prong connectors or is it hard wired to the fuse box. Could it simply be that the connection was knocked loose?
Thanks everyone, I feel welcome to the Pelican family. Already dumped a bunch of $$$ here, too...yippie!
MarkY 01-13-2005 06:54 AM
Four years ago I purchased a low milage 88 coupe. Everything works except the glove box light, which acts exactly like yours. Works manually only. I tried every remedy posted above to no avail. I finally said the hell with it, although if you get yours working, please post the fix.
js1099 01-13-2005 07:33 AM
It will be my pleasure...if I get it to work.
cicsprog 01-13-2005 09:23 AM
I had this issue also on my 88 Cab there and on upper map light. Take some 600 grit sandpaper and clean up the contacts on that pin and round socket (for lack of better terms) that rotates the light from on/off. Make sure the entire light assay has good contact with the hole it fits in – I think that grounds the circuit and make the light light. I use a product called “R5 Power Booster” to clean dirty contacts – works great.
Jason 88 CAB
CrossT 01-13-2005 03:18 PM
I've had problems with both the switch and the light fixture. I just replaced the light fixture with a new one from our host and that 'no on/off with door' issue was solved. The switch was fixed by the same type of routine noted above - i.e., cleaning and making sure of the connection when the lid was opened and closed.
todd
86 coupe
RoninLB 01-13-2005 03:22 PM
a new glove door sw is cheap and and a brainless, quick install.
js1099 01-13-2005 04:07 PM
The million dollar "brainless" :) question is, how do I get the damn switch out, that's what I most need to know!!! You guys have been awesome I really appreciate all the feeback, and am enjoying Porsche ownership immensely. I did the hood shock replacement in 15 minutes, that was a breeze compared to this.
RoninLB 01-13-2005 04:29 PM
I just returned your PM.
scottb 01-13-2005 05:43 PM
You might be better off spraying some electrical contact cleaner in there, and then snapping the spring a few times.
js1099 01-15-2005 05:25 PM
With the help of those who said "brutalize" the spring in the switch, I say thank you. I flicked it several times, the light came on, then realized it needed some WD-40 to allow full travel of the plastic piece that makes contact with the door. Voila, it is fixed. Thanks everyone.
HarryD 01-15-2005 06:45 PM
WD-40 will shortly dry out and leave a gummy residue. Clean the switch with some contact cleaner and then use a decent lubricant like Tri Flow.
RoninLB 01-15-2005 08:25 PM
ditto
