brake switches
Well the brake lights are outon my 86 carrera, and i have got the switches exposed on the master cylinder. Was wondering if you can switch the wires from one switch to another. it seeems that cruise control needs both switches to operate but brake lights just one. Will any damage be done just unplugging the wires from the front swich and hooking it to the back one..see wich switch is bad or both...A new porsche owner and any help would be appreciated...Thanks
The switch is just a contact "triggered" by the brake fluid pressure so swapping wires for troubleshooting would not be a problem. I did the very thing on my '86 Carrera just last week.
My problem was the delayed response and/or extreme brake pedal travel required to trigger the brake light switch. I was disappointed after buying a new switch from a local auto parts store that the same delayed response was unchanged. I am seriously considering mounting a conventional contact switch directly to the brake pedal lever for the adjustability and instant response of brake lights. Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Brewster: The parts are cheap, and installation pretty simple. You can get the switches from our host or your local Kragen. Just replace them both and you'll be good to go.
1984 Targa |
Any ideas why when I replaced my switches the brake pedal must still be pushed with "excessive" force to get the brake lights to come on???
DRL: Air in the system? Bad master cylinder? When's the last time you bled the brakes?
1984 Targa |
some pelicanheads have posted on the poor quality of the triggering of some auto store sw's. I've also read that when the old sw is removed to press on the pedal to remove any crud that has built up in there.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks for all the tips, the brake lights work fine when jumped across the sensor off the master cyl. Went to the local parts shops and all the parts were not compataible with the plug setup on my 86. If anyone has a part number of where i can get a couple of these switches i would appreciate it...going for a ride the weekend so dont have time to order from our host. Any help would be appreciated...
do vw switches work in this application?????
I've heard the VW part is the same, but I don't have a cross-reference part number. Sorry for the hassle...
1984 Targa |
There are two versions of the switches, one with 2-pin connector [later models] and the earlier with 3-pin connector.
I don't know how many times this has to be said before some of you listen or actually look at a Porsche parts catalog ... Porsche uses a VW part number rather than one in its' own numbering system!!! How does that translate to a 'Porsche' part that is different, pray tell??? You guys that are buying generic parts from a local store don't have any right to complain about the switch quality issue! The VW part is made by Hella and comes mounted from Ate on new master cylinders! Do you have unresolved pedal bushing issues?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren: Do you know the VW part number?
1984 Targa |
113 945 515 G------------ 3-pole switch 1977-86
113 945 515 H------------ 2-pole switch 1984-89
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
