Fuel Injectors
I have a fuel injector in my SC that is wobbly...how do you tighten it....it just spins and spins...how can I remove it? Just can't figure it our and it is not in my Haynes Book, the 101 Book, or the engine rebuild book...thanks
John |
John
Chech this one....! <http://www.pelicanparts.com/techarticles/bob_tindel/911_inj_nozzle.htm> Or check on the tech Articles under CIS Fuel Injector replacement. Vic |
The fuel injector is held into the sleeve with an o-ring. Pull the injector straight up, removing it from the sleeve, and see if the o-ring is still intact. If not, replace with a new $.80 o-ring. If the o-ring is stll intact and in decent shape, the sleeve may be damaged....remove the sleeve, check for cracks, etc.
BTW: Its a good idea to replace the o-rings around injectors and sleeves as if they are bad, they are a good source for intake leaks.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
vizail.
Page does not exit???
John |
Even with new sleves and o-rings they still have a bit of movement when fully seated. I took a few pics to help you visualize how they look when removed. Hope they help.
but, how does it come out....do you just pull it?
John |
The easiest way that I have found to remove CIS injectors is to remove the fuel line and put a large nut on the injector threads. Then use a large square shank screwdriver to pry upwards against the nut to extract the injector. I have tried some of the "special" tools made to do this job but the nut/screwdriver method works the best for me.
Good luck with your project! Fred Cook '80 911SC coupe |
JWMC1
Don't Dare to pull it out with the fuel line attached to it..!!! There is a tool(FI puller) but you can get 2 brake Ajustment tools and pry it out. remember to apply the same force evenly and don't damage the treads. get a set of New Fuel Injectors O-ring's, and remember to put the o-ring's in a small container with gasoline this way you will make it more soft. Beleive me , you don't want and air leak on this area. I will try to post a picture of the tool ( puller) later Vic... |
the engine is out of the car and the entire fuel system is off
John |
The best improvement I made on my 83SC was new injectors !
As injectors go SC injectors are cheap. My SC had about 200,000 miles on it and my mechanic noticed one of them was leaking. New ones really made a difference. |
I will likely replace them all...that and the fuel lines...trying to do everything I can while the engine is out...new headers, gaskets, clutch...etc...
John |
