-   -   Cylinder head temp (http://forums.pelicanparts.com/porsche-911-technical-forum/201724-cylinder-head-temp.html)
jacko241 01-15-2005 06:49 PM
Cylinder head temp
Hey, guys. What would be considered normal safe cylinder head temp on a 3.0 SC twin plug race engine, 10.2 compression, on race gas? What about safe max temp? Joe
adomakin 01-16-2005 03:00 AM
can't help with the figures but you might get a better response in the engine rebuilding forum
ndy
randywebb 01-16-2005 11:25 AM
There was some discussion of this on this forum a few months ago - it was fairly general however.
The temp. you measure will vary a lot based on where you measure it.
jacko241 01-16-2005 11:45 AM
Yes, I know that there are many variables. What I am looking for is a generally accepted temp reading from a location that is commonly used for sender position, such as under spark plug on hottest cylinder.
randywebb 01-16-2005 12:44 PM
Did a search turn up anything? If not, re-post with your search terms and maybe someone can help you.
As I recall it was mostly a discussion on melting pts. of alloys.
jacko241 01-16-2005 01:41 PM
Ok, i'll try that. Thanks!
stlrj 01-16-2005 02:45 PM
It seems, at least in general aviation, that they like to see CHT's at less that 400* F for longevity.
When aluminum reaches 450*F it loses its strength very rapidly.
-Joe
jacko241 01-16-2005 02:55 PM
That sounds reasonable. I talked to Ron Zitza of Zotz Racing in Orlando at the November HSR race at Sebring, and he says they like to see between 300-350 degrees.
