armandodiaz's Avatar
Quick help on tires
Well I waited too long to order my tires and now I need new tires for this weekends DE.
My plan is to put BFGoodrich g-force on my BBS 7X8X15 rims.
fronts: 205/50/15
rears: 225/50/15
Problem:
My local dealer has plenty of the rears in stock, but the fronts have to come in from out of town. He says earliest Monday (too late).
Question:
Can I fit 225/50/15 in the front? The car is an 85 Carrera stock suspension, alignment and height. Will it stick out from the flare? Does anyone have pix?
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 01-18-2005, 11:34 AM
I tried 225s on my 7x16 on the front and they rubbed too much. You may have better luck with 15s since you will have more clearance with the smaller diameter wheel right?
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 01-18-2005, 11:36 AM
Hi Armando,
I ran with 15" wheels at Moroso last weekend, and they have always worked fine. My car is very low, lowered to Euro specs, and I've never had a problem with 15" BBS wheels.
Just as a rule, it would be best if you have rolled fender lips, and if you do, then you will have no problems with the 225 on the front. You might take your 225s from the rear, and put them on the front and see how the clearances are.
Write me for more specific questions if you wish: anagy@zeidlerpartnership.com
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 01-18-2005, 01:33 PM
If you have to put 225s on the front, you should consider 245s on the back to balance the 10% tread increase up front.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 01-18-2005, 01:45 PM
tough to find 245s in a 15". I think with the 8" in the back it should give it a wider stance than the 7" in the front.
Armando Diaz
Old 01-18-2005, 02:49 PM
The 8" will spread the bead apart but the tread contact with will be almost unaffected. I know about the problems getting wider 15"s these days, my urq has 15x8 all around and the guys running 15x9s on 930s frequently lament about the lack of choices.
Dunlop SP8000s tend to show up in 15" diameters with a decent width/aspect range, don't know if your shop can get a truck from their distributor but you could ask.
Charlie Baer
Old 01-18-2005, 02:56 PM
I called them at 10am, they didn't call back until 1pm. Then they tell me they would have been able to get the tires if the order would have been in by 12pm. Of course I had a few choice words (*%#@!#) for them since I did call them before the 12pm deadline. If they weren't so dam cheap I'd tell them to f**koff.
Armando Diaz
Old 01-18-2005, 03:04 PM
Shaun @ Tru6's Avatar
I've done an extensive search for 245/50 15s in thinking of putting 8x9x15 Fuchs on my 84 and a max performance solution just doesn't exist. Here's what does:
8000s as you mentioned
Hoosier
Goodyear makes a 13 inch slick that will fit a 9x15
and at a Pantera site, found a set of 245 Euro T/As that are new.
I've talked with many departments within Michelin and BF Goodrich, and they are all gone.
as to a 225 fitting in the front of a lowered Carrera, I run 225/45 17s in the front of mine, very low, fenders rolled and don't have any problems.
Tru6 Restoration & Design
Old 01-18-2005, 03:17 PM
Right now I have 235/45/17 with 1" spacers. I have no problems (I did have to lift the lip at the track with a prybar, once). If these fit should I assume the 225/50/15 should work?
Armando Diaz
Old 01-18-2005, 03:41 PM
They work on my Euro-lowered stiff suspension 911SC.
Andras
Old 01-19-2005, 04:32 AM
I've taken this into consideration, as well as the availability. I've decided to go with the only place that can gurantee the right size tires."The tire guy" he shows up at the track with a truck full of tires and equipment. I called him up and he told me he has the 2 sizes in a Toyo Poxie RA. I really wasn't looking for "R" compound yet but if this is the only thing available and they are the same price, then I'll run with it.
Armando Diaz
Old 01-19-2005, 05:28 AM
Armando,
Is the "tire guy" by any chance Ernie Bello? If so, he's a great guy, and a very nice person. Also good to work with, as he knows his stuff.
He also allows us up north here to inspect our cars for DE events.
Andras
Old 01-19-2005, 05:39 AM
It's Jason Barrto, he is officially know as "The Tire Guy" (it's on his buisness card). He's usually at the track with a truck full of tires and equipment (mounter, balancer, shaver...). This will be the first time I use him, but I've heard of others talk good about him.
Armando Diaz
Old 01-19-2005, 07:24 AM
Armando, would you mind asking his opinion on a track tire for a 9x15 Fuchs rear? Car will be used on both street and track, I could probably groove the tires myself or have a shop cut them, and if I got 5000 street miles out of the rears, I could probably live with that. Of course DEs will shorten that life considerably.
Old 01-19-2005, 07:39 AM
Shuan here's his number 770-266-5659 his name is Jason. His email is:
tirguy@aol.com
Armando Diaz
Old 01-20-2005, 08:00 AM
thanks Armando, sent him an email.
Old 01-20-2005, 08:14 AM
