fitting SC alternator in early car
guys;
the car is a '69E. it was already fitted with an internally regulated Paris-Rhone and i don't recall this being an issue. that unit is no longer available to me. onward... the replacement works fine BUT it is longer than the other unit such that the 2 pullies are no longer in plane. i presume my options are;
1) upgrade to a later housing or;
2) mill the existing housing to fit.
if (1) which years do the trick and are there any other considerations ? if (2) then does anyone know the exact amount of material to remove ?
any other options ?
thanks all.
cheers
jerry... starting to chomp at the bit.
Old 02-23-2005, 03:01 AM
Early_S_Man's Avatar
Porsche Crest
Jerry,
The 1975 and later housings were machined 9.3 mm deeper to accept the 980 Watt alternator's case. The replacement doesn't have to be a Valeo or Paris-Rhone -- the more reliable Marchal/Motorola 980 Watt with separate regulator works, too, and is a better choice!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-23-2005, 07:15 AM
Senior Member
Superman's Avatar
When we play 911 Trivia, I want to be on Warren's team.
Mocha 1978 911SC. "Coco"
Old 02-23-2005, 07:26 AM
count me in! this isn't the first time Warren has come to my rescue. the tip re: outboard regulators is well taken and not the first time i've heard it mentioed. one more piece of trivia ? my understanding is that there is some difference between the units mentioned above and the Bosch units. can "someone" outline that difference from the standpoint of interchangability ? ;-)
thanks again!
best
jerry
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 02-23-2005, 02:33 PM
