-   -   CIS to EFI conversion thickness (http://forums.pelicanparts.com/porsche-911-technical-forum/202153-cis-efi-conversion-thickness.html)
bb 01-18-2005 09:16 AM
I am going to build an airbox for my EFI conversion and am wondering how thick the steel should be,(wether I use stainless,Carbon steel, or Aluminum)?
Oscar
tbitz 01-19-2005 07:56 PM
Here is something to think about.
Cutting the throttle at speed can create a vacuum in the airbox of 10psi. If your air box has a surface of 6" x 10" (60 in^2) this would result in an 600lbs force on each side trying to collapse that surface.
Cheers,
bb 01-24-2005 09:13 AM
So how thick should I make the airbox?
Oscar
