vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Exhaust Removal - Hot or Cold?
I gutted an old muffler and want to remove my current muffler and try the gutted one, but was wondering if I should heat up the engine, or leave it cold - which way will make it easier to remove the muffler from the car?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 01-20-2005, 11:15 AM
goat's Avatar
Cold.
I had to dremel the bolts off cause they were quite rusty.
Added a little time to the project.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 01-20-2005, 12:10 PM
efhughes3's Avatar
I wouldn't mess around with the PB blaster. Go straight to the torch-less cursing and you'll get each nut off in fairly short time. You need to use something stronger than a propane torch, and get them red hot. A quick blip toward tight, and then the nuts should back right off.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-20-2005, 01:11 PM
