Ways to tell original color of 911
Is there a way via the VIN or option codes to tell what the factory color of a 911 is? I have a triple black 1988 cab and I want to confirm that black is the original color. Anyway to do so?
thanks, Mary
Lady 911 driver 1988 triple black 911 cabrio 2005 Saab 9.3 Cab 2.0T 65' Cobra Replica race car http://norcal-cobras.com 65' Cobra replica under construction 2001 Ford F250 TD 4WD (the Tow Monster) 1993 Chevy Camero LT1 "Life is too short to drive a boring car" |
Open the front and look along the left side under the snap-on fabric and you'll see a decal with the code and name of the factory color.
1984 RoW Cabriolet - GP White |
Thanks! I will take a look in the morning.
Take a small swiss army knife or similar. Make 2x deepish scrapes across the top of the fender. If it is black down to the primer then you have the answer. If uncertain, repeat procedure on hood.
![]() >edit< on reflection that was a little misleading. For and old car that you are about to repaint it's a perfect technique though! Best advice- folow rrpjr's advice...
'72 911 T/E Silver Targa Last edited by Matt Smith; 02-03-2005 at 10:54 PM.. |
The engine area on mine was left silver everything else is primer.
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Gon fix it with me hammer
run the vin through the porsche archives...
mine had 2-3 colours on it , but the archives revealed that the original colours was not in the list of colours i had found on the car... heck , even the interior was changed ...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
My '76, '74, and '72 has the paint code on a plate on the driver side door post close to the hinges. Later cars don't have this?
edited to say door post, not jamb
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com Last edited by Rufblackbird; 02-04-2005 at 09:28 AM.. |
The VIN has nothing to indicate vehicle color.
You need to find the options list on the underside of the trunklid, or, as Rufblackbird stated, on older cars it's on the driver's door post.
Mike B. '72 911E Coupe Early "S" #1065 |
It's even simpler than this !!!
Look at the VIN sticker on the driver's door jamb....it has the VIN ( and possibly other) numbers shown as "perforations" on the sticker. So.... Look at the color that shows through the perforations.....very likely that which shows through the perforations will be the "original" color .......since it's unlikely the VIN plate was disrurbed in any repaint process. Wil EDITED FOR BETTER CLARITY
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-04-2005 at 06:26 AM.. |
I found the options sticker this morning exactly where "rrpjr" said it would be. Only issue is it is so faded I can't read it
I did pull up all the trunk carpet and looked everywhere on the car and it appears the car is a factory black car. No other colors found lurking in hidden areas. The issue that got me searching in the first place is when I was waxing the car and detailing I noticed that on the inside of one of the fenders had some red showing through the rough painted area where rocks would hit from being kicked up from the tires. Maybe this fender has been replaced over my p-cars 17 years of life....but the repaint on that fender must have been of amazing quality cause you can't see any blending, overspray or masking evidence.I am essentially trying to learn more history about my car, which I absolutely love btw ![]() thanks everyone for your input! Mary
