| 304065 |
01-20-2005 11:09 AM |
No problem, many folks here include that information in their autosignature line, accessed through the user cp button.
So you have a '76 with an external voltage regualtor. Since the alternator is putting out 14.5V, you know that it's working OK. But the fact that it's 14.5v makes me suspect that the external voltage regulator is going bad: the set-point for charging should be closer to 14.0v. The VR is a metal can located on the electrical console on the port rear of the engine compartment, behind the plastic watershield. If you change it, make sure you get the same manufacturer as your alternator, e.g. bosch for bosch, motorola/marchal for motorola/marchal. (If you use a different brand, the setpoint is usually different)
The only other thing to check is to verify that all the connections in the "blue wire" circuit are corrosion and crud-free. This is the blue wire that begins on the back of the alt, runs to pin #11 on the 14-pin connectors on the electrical console, runs forward through the wiring harness to the back of the oil pressure gage, then through the bulb holder and into a red wire with black stripe to the ignition switch. If you pry out the gauge, don't pull off the wires, and for sure, don't inadvertently short any of them together. What might be happening is a loose or intermittent connection in that circuit resulting in no-charge, then you hit a bump or something and reestablish continuity, which turns the juice on, but since the battery is so low, the alt goes to maximum output, pretty close to 14.5V.
Good luck!
