Plavan's Avatar
More early 911 weights--- 901 tranny Alum vs. Mag....plus LSD weights
Hi Guys-
I thought you would like to know more info on weights of 901 trannys.
My father and I are in the process of swapping out our aluminum 901's to Mag 901's so we can install the Guard 80% LSD.
Allan at Aase weighed the shells and parts and this is what he came up with:
30.36 pounds aluminum case empty
22.41 pounds mag case empty
17.20 pounds limited slip differential (Guard 80% unit)
9.94 pounds stock differential
2.12 pounds stock intermediate plate
4.06 pounds aluminum billet intermediate plate
More weight info for you rennlight guys
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 03-01-2005, 04:14 PM
KobaltBlau's Avatar
cool data. what type of scale was used, do you know?
Andy
Old 03-01-2005, 04:27 PM
Plavan's Avatar
A nice digital scale seen here.
Chad Plavan
Old 03-01-2005, 04:39 PM
pjv911's Avatar
Send a message via AIM to pjv911
Chad that mag case unit your using is not really a 901 . Its a type 911 and was used for 70-71 only . I recall you were searching for a type 901 unit in magnesium . As far as I know there is no such thig as a 65-69 magnesium case . As far as the type 911 goes it is exactly the same aside from the case and the type of clutch is requires . It also has a better gear spread for more powerful engines also a higher(highest) 5th gear of all the 65-71 trannies . Great data btw . Thanks for sharing .
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 03-01-2005, 05:00 PM
pjv911's Avatar
And yes the type 911 unit does have 901 #`s all over it . But its still a type 911 .
Kurt Williams
Old 03-01-2005, 05:02 PM
Plavan's Avatar
I was keeping it simple. I just stated "901" because thats what everyone is familiar with. There is a 1969 mag 901/911. My dad's project car was a 69 T and it had a mag 901/911 in it. He is throwing his LSD in it right now. Thats why I was looking for the parts for mine. One thing that is unique about a 1969 mag tranny is bowden tube size on the side cover. Its different for 70/71 models. Not to mention it makes it very easy to bolt everything right up with the Guard LSD.
Chad Plavan
Old 03-01-2005, 06:05 PM
randywebb's Avatar
BTW, AFAIK, that is not an official designation - but it's good to keep things neatly sorted. Also, I think there were some other differences between the 901 and '911' - search Grady's posts if interested...
Thanks for the wt. data!
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-01-2005, 06:19 PM
