Engine type?
My '75 911S has engine number 6152262 and engine type number 911/43 or the 43 may be a 48. Does anyone know if that is the correct engine for my car? It has an 11 blade fan with a sticker indicating it conforms to 1977 emissions standards....
Thanks! |
I'm guessing what you mean is engine # 6452262/43 which according to the red book is 911 S (USA 49 State) of which 2,310 were produced. The engine # 6152262 doesn't seem to match up. The 6452262/43 -
90-millmeter bore x 70.4- millimeter stroke 2.7 liter, 2,687 cc k-jetronic fuel injection air pump emissions control 165 hp at 5,800 rpm 167 ftlb torque at 4000 rpm *designated 911/48 with sportmatic (tranny) hope that helps. |
Kelly,
Welcome to the Forum. It is customary to post pictures of your 911. According to my ’75 Factory Spec Book the engine is a ’75 normal 911 (not S or Carrera). Engine Nr. 6152262 6 = 6-cylinder 1 = 911 (not S….) 5 = 1975 2262 = sequential number The Type number doesn’t jibe. Type 911/41 is the normal 911 Type 911/42 is the 911S Type 911/43 is the 911S/C (USA) Type 911/44 is the 911S/C California 911/46, 47, 48, and 49 are Sportomatics as above. 911/83 is the 2.7 Carrera 210 HP. 930/50 is the 3.0 Turbo. Carefully inspect the numbers. See if they look original or any sign of tampering. What is the VIN on the chassis? Inspect it in four places; driver’s door jamb decal, chassis stamping to right rear of fuel tank, aluminum placard ahead of the RF shock tower, and drivers windshield post. If something turns up suspicious, there is a hidden number. Best, Grady |
Thanks guys!
Well, I took a magnifying glass and it is definetley 6452262 and the type is definetley 911/43, so It looks like I have the original engine with a '77 cooling fan abd shroud. How do I post a pic of my car?> |
To post a photo of your car, hit the "reply" button, and below the text box, but above the "Submit Reply" button is a link that says "Click Here to Upload a Photo". Click on it, and select the file you want.
If you have a photo up on a website, then hit the "IMG" button above the text box, and past in the URL. Hope this helps! Welcome to the board. SmileWavy |
Pic of my project car.
Here is a pic of my project car. It is pretty apart right now. Its a 75 911Shttp://forums.pelicanparts.com/uploa...1106485608.jpg
Im far from being an expert but is that a short hood conversion?
I dont thinkso. It was bought for a girlfriend, who immediatley ubused and neglected it, and It has sat for the past 10 years. its some story. I bought it for $900 in September. Going thru it now...........
$900 did you say $900? That is for FREE :) does it run? Man, talk about the right price........i got severe deal envy
I haven't started in earnest on the engine yet. I can make it run for a few moments by spraying gas down the throttle bodies, which tells me the FI needs work. there was some corrosion on the body, most of which I have repaired since September. No corrosion on anything structural, tho.
I am just finishing up the front steering, brakes and suspension work, and will start on the rear brakes and suspension next week. Then I will have to decide if I want to tackle the FI myself, or farm it out. Here is a pic of the front steering brakes and suspension build for one of the front wheels. Thanks for the interest!http://forums.pelicanparts.com/uploa...1106498759.jpg |
| All times are GMT -8. The time now is 08:04 PM. |
