Who's done the lightweight hood swap?
Was it worth it? I'm guessing its a 15 lb or so savings. Is it a simple swap? Hood pins necessary? Words of advice?
1980 911SC Targa 3.6L
Old 01-22-2005, 02:12 PM
Send a message via Yahoo to Lukesportsman
If you go street weight, you should be able to retain the hood latch depending on the manufactor. You do want to remove the hood struts, of course this means more weight loss
Depending on the "perfection" you have in mind, it can simply be as simple as bolting it on and adjusting the latch. Then again if you want it to fool people, you've got some detail work ahead of you.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-22-2005, 05:09 PM
Thanks Luke--what kind of detail work?
Old 01-22-2005, 05:10 PM
randywebb's Avatar
for wts. look at my spreadsheet on Thom's web page, rennlight.com
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-22-2005, 05:36 PM
