Paint-How Many Layers?
How many layers are in factory Porsche paint?
I ask because I am using aircraft stripper to remove the paint/primer from the front bumper and valance of a 1978 SC, prior to repainting. This vehicle is the original mocha brown, unwrecked, or repainted (as far as I know). So far I have encountered the brown surface laquer, followed by grey, then yellow, then a very hard brown. Under that is white then metal. I am starting to consider as very reasonable, the $200 price quoted by the body shop to strip the paint. |
I feel your pain. When I restored my SC, I stripped both front and rear bumpers down to bare aluminum, inside and out. I used a similar commercial stripper and carefully used a dull putty knife (the aluminum gouges easy!), along with 400-600 grit wet sandpaper. It took ALOT of work, but came out great. Just be patient. Mine appeared to have just 2 layers. The actual GrandPrix white, and then a slightly more yellowish primer layer. I would suspect you are uncovering some layers of prior repaints and primers perhaps?
When I stripped my 77 924 back to bare metal (the whole car) it took forever. A great deal of patience is required and please don’t get stipper paste in your eye like I did.
I guess I should be more patient. Time to get the sandpaper out. I have been gently using a thin putty knife to remove the paint, stopping just before the final layer.
If this is a repaint, they did a heck of a job, as these color layers are the same on the backside of the bumper as well! |
Put some plastic wrap over the paint stripper and let it sit awhile.
It sounds like your car has been repainted. If you couldn't tell they did a good job. The factory paint is usually a whitish/grey primer followed by the actual color.
Yea -what Kurt V said
My original GP white has an odd brown/yellow green primer under the grey... So does my SC...
| All times are GMT -8. The time now is 04:24 PM. |
