-   -   Lazy Man's suspension work (http://forums.pelicanparts.com/porsche-911-technical-forum/203050-lazy-mans-suspension-work.html)
greglepore 01-24-2005 12:07 PM
Front suspension question-I'm doing tbars and upgrading to a 22mm sway; figure maybe I should do A arm bushings as well. If I'm not changing out tie rods or ball joints, can I simply remove the ball joint wedge bolt and unbolt arm mounts and tbar brackets and drop both arms and sway as a unit? Any problems getting everything reinstalled if I do this? Looks like it should work, but thought I'd ask first.
jpnovak 01-24-2005 12:16 PM
Yes, that works. don't forget to unbolt the steering rack from the cross member. the other option is to remove the cross member bolt off one side and pull the a-arm out.
Chuck's Elephant Racing bushings are nice.
