It seems like you are saying that when the C8 is fully charged nothing is returned to the battery. This is clearly incorrect. The first scope photo shows that. You can't argue that just by saying it dosen't work that way. "Who you gonna believe, me or your lying eyes". |
The current cannot decrease instantly to zero when T1 shuts off. |
It's simple:
Energy In ~= Energy Consumed Watt-second = joule Power In = 1.0 amps X 10 volts = 10 watts Osc. Freq = 3.3 KHZ Energy In = 10 watts X 300us = 3.0mj Energy stored in 1uf capacitor when T1 switches off = 80V X 80V X 1uf / 2 = 3.2mj Therefore all the energy intially stored in the osc. system is consumed and basically none is returned. The energy is consumed by the forward biased zener (during the dumping of the L current - after C discharges) and T1. |
C8 charges to 460 volts to provide energy for the sparkWhat is being discussed is how when C8 is charged energy is returned to the battery. The mechanism is exactly like how the flyback in a horizontal deflection coil in a CRT works. Ramp up the current, turn off the Horizontal Output Transistor which dumps the energy into a capacitor and the L-C reverses the current and rapidly returns the beamIf energy is not returned to the battery when C8 us fully charged how do you explain this? Quote:
"What is being discussed is how when C8 is charged energy is returned to the battery."
It's not. The proof indicates such! "Are you talking about the zener diode being in reverse breakdown or forward bias?" It's forward biased. The LC oscillation ends because of the zener across the capacitor, i.e. the zener acts as a diode (forward bias) and clamps the capacitor from charging in the reverse direction when the inductive current is negative. The base emitter diode and the collector base junction of T1 can act as a diode without the zener. "I don't have one to experiment with but I am pretty sure you could replace the zener with a 1n4003 and with a 12 volt input the output would still be ~460 volts" Correct! "You do agree that these voltages on the primary during flyback would limit the output correct?" No! As I said before, a .10uf still produces the same peak output. If the simulation worked properly, it should indicate that too. |
If the Zener diode was replaced by a simple diode as in the Rick-I's simulation the output voltage would be much higher with a 0.1 µF C1, as I have shown in a previous post for some other values for C1. With a 0.1 µF most of the energy in excess at low rpm is dissipated in the Zener diode rather than being returned to the battery as it is with a 1 µF C1. This is clearly visible with the power consumption figures I have provided earlier. Quote:
"Proof ? Which proof ?"
Are you brain dead? Energy In ~= Energy Consumed Watt-second = joule Power In (consumed) = 1.0 amps X 10 volts = 10 watts Osc. Freq = 3.3 KHZ Energy In = 10 watts X 300us = 3.0mj Energy stored (and then consumed) in 1uf capacitor when T1 switches off = 80V X 80V X 1uf / 2 = 3.2mj WHERE'S THE ENERGY RETURNED?????????? AND maybe you just can't properly understand what the scope traces actually MEAN! What a waste of time. |
A real "proof" would have been to demonstrate that my pictures and figures were invented. I recognize that it is always difficult to contradict facts, but to treat me of "brain dead" does not seem to be a valid alternative. Quote:
"A real "proof" would have been to demonstrate that my pictures and figures were invented."
Not invented, just doesn't understand what's really happening. "If the current in the primary is negative isn't it going back into the battery?" Correct! But that doesn't mean the energy is saved. The coil's current just flows thru the power supply (remember power supply is basically a voltage source with zero ohms) as it charges the capacitor and as the capacitor re-charges the coil (field builds up in the coil). The coil trys to re-charge the capacitor but the coil current by-passes the capacitor because of the forward bias diode which results in a loss of energy. Furthermore: Energy In = 10 watts X 300us = 3.0mj Energy stored (and then consumed) in 1uf capacitor when T1 switches off = 80V X 80V X 1uf / 2 = 3.2mj Energy stored in the coil = 4.6 amps X 4.6 amps X .30 mh X .5 ~= 3.2 mj Iavg = 1.0 amp = Ipeak X .5 X Duty Cycle = 4.6 X .5 X D.C. Duty Cycle ~ = 45% Bottom line: All the calculations basically indicate the same; Little to no energy returned! There's NO mis-interpretation or one's VIEW (scope traces) when it comes to equations. The numbers don't LIE. |
jmchrist I have learned alot from your scope photos and help with analysis |
Bosch 6 Pin CDI
Where can I get a C8 1.4uF 600v capacitor for my 6 pin CDI? Is this just a standard capacitor??
Tim |
I have used a this one successfully a couple of times in the past: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=EF6155-ND. I have not been able to locate the original style capacitor. Let me know if you find something other that matches closer.
Cdi
Hi gents,
After testing I found that C8 was open circuit in my CDI. I replaced it (and also fitted a bigger SCR) and now it all works again. I wanted to leave it running on the bench a while before re-firtting it to the car. What input frequency should I use to simulate 8000RPM? I figure if it works OK like this then it will be fine when on the car (clearly I don't rev mine to 8k) I reckon it is approx. 400Hz Can anybody confirm this or tell me what it is? Thanks for helping... Steve |
8000 rev/min * 3 sparks/rev = 24,000 sparks/ min divided by 60 = 400 sparks/second or 400 Hz
Thanks Rick :)
Regards Steve |
What is the "SCR"? Sorry, I know zero about electronics. |
Silicon Controlled Rectifier.
Holly molly, what's a wonderful world. I can rebuild this module in no time with the schematic. thanks u so much.
The issue of "surplus" C8 power/charge. Once the plug's spark/arc extinguishes the ignition coil's magnetic field begins to decay/collapse, voltage reverses and the coil's primary current flows around the "circle" (through the secondary of the inverter transformer) and back into C8.
So C8 ends up already partially charged when/once the inverter restarts. Note that once the SCR is fired, remains fired, the inverter transformer secondary is shorted. |
Which type(s) of capacitors are best for replacement?
I saw that a mylar capacitor could be used for C8, but what should be used on C1-C7? Thanks a bunch. John |
This is a cross post from when my SC broke down on sunday but I thought it might be good to show how easy it is to follow Warren's post and replace a faulty CDI C8 cap. Car started on the first crank after replacement. The soldering is pretty easy so I would recommend giving it a shot if you take your time and take pictures during the whole process. Thanks to Warren and everyone else for all of the info in this thread! Chuck
I revised this post because I had to switch the C8 cap to the part from digikey listed a few posts back http://forums.pelicanparts.com/uploa...1312404868.jpg http://forums.pelicanparts.com/uploa...1312404936.jpg |
Polyproplylene?????
Maybe guess again! Bottomline: Bring a spare CDI in the car. |
Lorenfb, thanks for the response. Since your a D$$k 99% of the time I shouldn't expect much from
your posts. It's really pretty simple to fix again or replace with an MSD if it comes to that. Btw, your people skills suck :) |
I am not sure you are in trouble. Let me think about this for a minute but I am not sure you exceed the 150 V/uSec rise time. If you are not at 100 deg C even better.
http://www.wima.de/EN/WIMA_MKP_4.pdf |
Thanks Rick, I can swap out the cap if need be with another suggestion that I had. Chuck
Update: I swapped out the incorrect replacement cap that I used for this more correct one. Digi-Key - EF6155-ND (Manufacturer - ECQ-E6155KF) |
"I am not sure you exceed the 150 V/uSec rise time."
Oh, so that's the only key parameter, right? Using the same logic: My trans in my 356 SC has an input bearing problem. Thought I'd use an old VW trans as they are; both 4 speed, both are trans/axel, appear to bolt-up O.K., so why not give it a try. I don't think that I over-looked any key parameters or anything that might be problematic, right? Maybe others on the forum might find this info useful in solving their trans problem even though I have little experience and knowledge in fixing/installing a trans. This solution does seem reasonable, though. |
So what is the key parameter then?
I hear ya. I actually PM'd him about a suitable replacement before I did anything but he would rather argue with people than simply provide a solution. Never got a response back from him.
Want to see the inside of my C8? I too am trying to find a suitable replacement. I saw absolutely no markings on mine.
Hi there, first post, already looking for help!!
Have a '76 SC with a blown CDI and a will to repair it. I have a blown 31/1 terminal - looks to have got hot and subsequently failed. Additionally I have a burnt R2 (ouch ?!) anyone recommend a suitable replacement / outlet to supply the parts? I've looked about and can only find '10 Ohm 1/4 Watt 5%' rather than the specified '4 Watt' type - am I missing something? All advice greatly appreciated. |
I talked to a capacitor manufacturers applications engineers today and described the CDI waveform and he said Metalized Polypropylene was the way to go.
WTF?? |
Mouser 4 Watt, 10Ohm, Wirewound Resistor |
Mouser Metallized Polypropylene Capacitors |
OK, sorted the resistor issue, now I need a C1 Capacitor - Siemens 1.0mF 250 volt - rarer than rocking horse poo................?
Anyone suggest an alternative? |
B32232A3105K http://www.digikey.com/product-detail/en/B32232A3105K/495-3529-ND/1647810 |
| All times are GMT -8. The time now is 03:04 AM. |
