-   -   6-pin SC/Turbo CDI unit repair documentation (http://forums.pelicanparts.com/porsche-911-technical-forum/203100-6-pin-sc-turbo-cdi-unit-repair-documentation.html)
Early_S_Man 01-24-2005 06:15 PM
Well, after a bit of a delay ...
Here's the schematic and replacement parts list for the Bosch 0.227.300.004 6-pin CDI unit, cussed & discussed at great length ... and used on SCs & Turbos thru '89!
http://forums.pelicanparts.com/uploa...1138414059.jpg
http://forums.pelicanparts.com/uploa...1138414270.jpg
http://forums.pelicanparts.com/uploa...1171863884.jpg
http://forums.pelicanparts.com/uploa...1183619700.jpg
http://forums.pelicanparts.com/uploa...1138415968.jpg
http://forums.pelicanparts.com/uploa...1090013680.jpg
http://forums.pelicanparts.com/uploa...1090013691.jpg
http://forums.pelicanparts.com/uploa...1090013700.jpg
Tim Polzin 01-24-2005 06:20 PM
Great work Warren. This is what makes this board as great as it is.
Tim
MotoSook 01-24-2005 06:27 PM
Excellent, Warren!
ChrisBennet 01-24-2005 06:42 PM
Awesome!
-Chris
randywebb 01-24-2005 09:21 PM
Now somebody post a circuit board pic
- That's defintiely $400 worth of parts isn't it.....
Grady Clay 01-25-2005 06:41 AM
Warren,
Thanks!
Here is the thread on the Bosch 3-pin. It has a wiring diagram also.
http://forums.pelicanparts.com/porsche-911-technical-forum/160537-perma-tune-cd-bosch-cd.html
Best,
Grady
Superman 01-25-2005 07:12 AM
Very cool. I just wish I understood.
Which of those parts fails, typically, when a Bosch CDI unit stops working?
jpnovak 01-25-2005 07:45 AM
Very Nice Warren!
Superman, I think the Thy might have the best chance of going bad. of course, there is always the chance of a blow cap, diode or resistor.
pwd72s 01-25-2005 10:02 AM
Too true, Supe...we mere mortals wouldn't understand. But in the right hands, this info is valuable. I try to have the info on hand for those with the right hands. ;)
randywebb 01-25-2005 10:53 AM
Component replacement and checking is not that hard on these older analog items. You could take a course at a community college and I'd bet 1 course would do it. This also helps stave off Alzheimer's if you are turning gray... If you screw it up, then send it in for re-grooving by a pro.
hobieboy 01-25-2005 01:06 PM
Great work Warren...
Another question - what about the pin-out for the 6 pin connector? Is there any place I can find that?
thanks...
Early_S_Man 01-25-2005 08:44 PM
Here is the pinout looking into the connector with the mounting flange sitting on the hand or table ...
. 31/1 ... TD ... 31d
. A . . . . 15 . . . 7
31/1 -- Power ground
31d -- Signal ground [green coax shield] for trigger signal
15 -- +14 Volt power lead
7 -- Trigger signal from distributor magnetic pickup coil
TD -- Tachometer Drive signal
A -- +460 Volt pulse output to coil
Early_S_Man 02-05-2005 08:26 AM
Here are some resources worth reading if you are a bit rusty on the theory of operation ...
http://www.irf.com/product-info/thyristor/manual/scr_manual.pdf
http://www.st.com/stonline/books/pdf/docs/4347.pdf
http://www.st.com/stonline/books/pdf/docs/5201.pdf
Early_S_Man 02-05-2005 08:52 AM
And, here is an application note from RCA that may be helpful ... after much difficulty with pic uploads [never copied the image code to edit window -- multiple attempts] ...
http://forums.pelicanparts.com/uploa...1107621185.jpg
http://forums.pelicanparts.com/uploa...1107621275.jpg
http://forums.pelicanparts.com/uploa...1107621352.jpg
http://forums.pelicanparts.com/uploa...1107621506.jpg
http://forums.pelicanparts.com/uploa...1107621640.jpg
http://forums.pelicanparts.com/uploa...1107621710.jpg
http://forums.pelicanparts.com/uploa...1107621796.jpg
http://forums.pelicanparts.com/uploa...1107621984.jpg
http://forums.pelicanparts.com/uploa...1107622083.jpg
http://forums.pelicanparts.com/uploa...1107622191.jpg
Early_S_Man 02-05-2005 09:28 AM
And, here are the last two pages of AN-6288 ...
http://forums.pelicanparts.com/uploa...1107624336.jpg
http://forums.pelicanparts.com/uploa...1107624504.jpg
silverc4s 02-05-2005 09:57 AM
I nominate this entire thread to become a PP Tech Article. Invaluable information from Warren as always, Thanks!!!
Early_S_Man 02-21-2005 01:19 AM
Here is a bit of design info from GE Semiconductors Electronic Data Library #400.6 on the single-transistor inverter as used by Bosch in our CDI units:
http://forums.pelicanparts.com/uploa...1108977264.jpg
http://forums.pelicanparts.com/uploa...1108977350.jpg
KobaltBlau 02-21-2005 10:15 AM
Truly awesome. Adding to the knowledge bank, Warren!
Grady Clay 02-21-2005 11:27 AM
Randy,
Thyristor is an early name for a Silicon Controlled Rectifier (SCR). The name is a combination of Tryratron tube and transistor. The beauty of an SCR is that a miniscule current or pulse can turn on a huge current and it stays on until the source current drops below a certain threshold. This is used in CDI and household dimmers.
Best,
Grady
randywebb 02-21-2005 11:59 AM
You're right -- I was thinking of thermistor.... Dunno whether to blame it on age or elapsed time since I've done any electronics work... I'll kill that post.
