PMO Fuel Pressure
Ok Guys, I hooked up a fuel pressure gauge to my PMOs. It gave me a reading 5lbs. Is that too high???
Here is the problem I am trying to figure out. During the warm up lap of my races, when i am scrubbing the tires to get heat in them, the carbs bobble very bad... Almost like they are running out of fuel or severe fule slosh. Well PMOS shold not have the fuel slosh issue do to the float bowl design. Once I straighten the car out and wait about 10 seconds, it is fine until I scrub the tires again. Then it comes back.. However under race conditions, I NEVER have a problem it is fine. No fuel problems what so ever. So I am baffled. Why only on the warm up lap???? I know the recomended pressure is 3.5 to 4 lbs is the 5 lbs going to hurt anything or could this be causing the problem some how?
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com Last edited by Vintage911Racer; 01-25-2005 at 08:39 PM.. |
try 3.5 or 3
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Re: PMO Fuel Pressure
Is it possible your engine isn't warmed up for the carb to atomize efficently ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Re: Re: PMO Fuel Pressure
Richard Parr at PMO reccomends 3-4 lbs for street cars and 4-5 pounds for race cars
I'll quote another idea from PMo's instructions "The fuel level should be close to the sandblasted dot in the window with engine running or slightly on lower side of dot. The fuel level will not stabilize on cars with solid motor - trans mounts.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
quote:
-------------------------------------------------------------------------------- Originally posted by RoninLB Is it possible your engine isn't warmed up for the carb to atomize efficently ? -------------------------------------------------------------------------------- Good thought... I will try the tire scrubbing thing on the coold down lap and see if it still happens. Thanks guys...
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
