2.0L alu case
Hi
may you tell me the max engine capacity to built on an early 2.0l alu case ? 2.8L ?
thanks
Best regards
Old 01-27-2005, 12:17 PM
If you have an early aluminum case, with a few upgrades (case savers, shuffle pins, oil squirters) it should be capable of supporting even a little larger, 2.9L (93 or 93.5mm bore). New heads studs, like supertec's or arp's would be good. ARP's new thru-bolts would be a great addition too (they will be ready in march from what I hear).
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Charles Navarro
President, LN Engineering and Bilt Racing Service
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-27-2005, 12:27 PM
thanks !
Old 01-27-2005, 12:32 PM
why not sell it to a small bore guy and use the profit to buy a 3.0 alu. case that is stronger?
mike k.
cblguy04210@hotmail.com
67 911 w/2.4e
Old 01-27-2005, 02:48 PM
dweymer's Avatar
Thats what I am contemplating right now, what is the value of these Alu cases?
Donnie
Currently Porsche-less.....
Old 01-27-2005, 02:50 PM
