PCA & MCSCC Instructor
robfike's Avatar
New cage and cell mount
I thought I would share some pix of the new cage and fuel cell install. The cell sits in 1" steel welded in angle. The angle should stiffen the front end also.
Old 01-27-2005, 05:31 PM
Cool! What size (G) is your cell? I can't read the markings on my monitor.
Old 01-27-2005, 06:01 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I ALMOST did the same type oil tank. very cool.......
Marc
Old 01-27-2005, 08:00 PM
robfike's Avatar
The fuel cell is a 17 gallon enduro model. It fits in the nose fairly well for a square peg on a round (sorta) hole.
Old 01-28-2005, 04:52 AM
collier's Avatar
Did you do your own tube bending?
I noticed that you are just up the road from Louisville....any chance I could get some assistance when my dipped shell needs a cage ? ? ?
C2
C2Motorsports Inc. 502.895.3660 | Engineering | Fabrication | Manufacturing High Performance Automotive Hardware and Software
70 911E*71 911T*72 911T*73 911*76 911 SC- Euro
Old 01-28-2005, 05:29 AM
Nice work...but what about water ingress? I would think a racing car should be as water-tight as can be, too....no?
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-28-2005, 05:54 AM
2 questions:
-Do you plan on closing the hole for the original fuel tank? Makes me think of running with an open umbrella...
-Where will you fit the oil filter?
Old 01-28-2005, 06:12 AM
robfike's Avatar
The cage was done by two great guys in Anderson, IN. They and their dad are renowned for their Corvair race cars. (I have one of those too). They do all of their bending on a quite well done home made hydraulic bender. I would be glad to put you in touch with them.
The hole in the front under the fuel cell will be closed off with some .025" aluminum.
The oil filter will be on a seperate mount up in the nose. Probably in the front right, as the fuel pump and fuel filter will be mounted in the area of the original battery.
Old 01-28-2005, 05:32 PM
collier's Avatar
Please send contact info for the Benders....
thanks,
Old 01-29-2005, 06:55 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
Looks like you will be much safer now.
Agree need a cover under your fuel cell, fiberglass covers are available or just cut the bottom out of the old tank.
Perhaps the oil filter was relocated when the sump was moved up front?
Any thought about running a couple short bars to the rear shock mounts from the rear legs. Maybe a lighter material X on the rear legs? I'd make the X horozantal and attach it to the main hoop about where your seat belt bar is. Helps keep the weight lower that way.
Looks like fun post more updates.
Old 01-29-2005, 08:32 AM
Elombard's Avatar
I was thinking the same thing Ted. Looks great but i wonder about the shock towers. In a high speed bump most of the force into the chassis would be transmitted through the shock.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-29-2005, 08:40 AM
