Various Flare sizes
Here is a dumb question: Does an 11" RSR flare extend out from the original panel by 11 inches, or is it called that because you can use an 11" rim?
Follow up question: How far from the original panel do the following flares extend out: SC Turbo RS RSR |
11" rim width.
Usualy the flares are described by the wheel that will fit, a stock 930 uses a 9" front and 11" rear flare, the biggest wheels that are usually used w/ them are 9 & 11".
| All times are GMT -8. The time now is 10:04 PM. |
