Mahle 2.7 High Compression Pistons
I was looking at an engine that the owner claims was rebuilt 9 years ago with high compression Mahle 2.7 pistons. He showed me a copy of the work order and the part number for the piston and cylinder set is 911103949HP. It appears to be the same number as the CIS pistons with the HP at the end. Is anyone familiar with a high compression set made by Mahle with that part number?
2.7 lts. Mahel CSI compression 8.5:1 part# 911-103-949-01
X/A |
Since that number appears to be for normal CIS pistons ... either the owner is misinformed or trying to misrepresent what is in the engine! Some people call the 175 hp 1974 911S CIS pistons 'high compression' ... when compared to the base 911 engine pistons for the 150 hp model!
Ask the owner for the compression numbers, and to do the test in front of your eyes ... an 8.5:1 engine will produce 170 - 190 psi, whereas high compression pistons should produce 200+ psi test numbers!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 01-28-2005 at 08:05 PM.. |
Thanks for the information... This is helpful.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Make My Day
2.7L IS EITHER 8:1 OR 8.5:1 SO HE'S BEING UP FRONT WITH YOU. AFTER NINE YEARS AND A COLD ENGINE(IF ENGINE IS OUT OF THE CAR) DON'T EXPECT THOSE KIND OF NUMBERS
74 911S Targa ROW Building Designer/Business Owner |
Warren, I have a 74 911S and it only produces 155ish specs at cranking for compression, although I suppose my battery could spin the engine faster for higher numbers. I bought some used pistons at one time though, and I recieved two types due to shipping complications. One set looked like the above shown set, my set, IIRC doesn't have quite the same size hump (although the wrist pin must be higher, relatively, to yeild higher compression). Both types of pistons were from CIS 2.7's, so more than one compression ratio or type must have been used in 2.7's. Then again, I have a California model so maybe my 911S has low compression pistons (voiding my wrist pin idea)???
The engine is in the car. He claims they are 9.5:1 or greater. I read through some posts and there was mention of a high compression euro piston that Andial was selling. I thought it may have been those.
Make My Day
I DON'T BELIEVE MAHLE EVER MADE 9.5:1 2.7L PISTONS
Those are for the 911 U.S. specs. the euro part #911-103-928-01 compression 8.5:1
The 9.3:1 are for 1980-83 3.0 lts. part#930-103-977-03
X/A |
X/A |
Here are a couple of the posts that mention higher compression 2.7 pistions.
2.7 RS engine CR increase? 2.7 Mahle P&C's
I'm running mahel 2.9 lts. high compression (10.5:1) on my '74 Carrera and yes they make HC pistons & cyls. but jus to upgrade the 2.7 lts. to 2.8 (RS 9.5:1 ,RSR 10.5:1) and 2.9 lts.
X/A |
Doesn't want/need a 3.6L
Mahle makes a 90mm piston and cylinder that is rated at 10.3:1. This is for 2.4L and 2.7L engines with MFI or carbs. For an RS, it raises the compression from 8.5:1 to 9.5:1
Bore: 90.0mm Cyl height: 85.6mm Piston Pin: 22x58mm Comp Ring 1: 90x1.5 Comp Ring 2: 90x1.5 Oil Ring: 90x4.0 Head Gasket: CE-Ring I could give you the Mahle internal piston and cylinder part numbers, but then I would have to kill you. Ralph |
Make My Day
NOW I'M CONFUSED
The current Mahle high-compression piston sets are a recent development -- less than five years old ... so, that would preclude their use in a rebuild nine years ago! Besides, they don't have Porsche part numbers!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
You are right with the statement that the sets don't carry a Porsche part number, never said they did. Don't know if these sets are still available or not, but they did exist for quite a long time. Ralph |
Here is the info that I have for 90mm pistons & cylinders. Note that this is from my notes that are from the late '80's so don't consider it up to date:
Stock Pistons & Cylinders 911 103 928 01...90mm w/ 8.5:1 CR...Nikasil Cylinder 911 103 949 00...90mm w/ 8.5:1 CR...Silumal Cylinder 911 103 949 01...90mm w/ 8.5:1 CR...Nikasil Cylinder 911 103 951 01...90mm w/ 8.0:1 CR...Nikasil Cylinder "Racing" Pistons & Cylinders 90mm w/ 10.3:1 CR*...Nikasil Cylinder *CR may vary depending on components used BTW, I have no idea what Silumal cylinders are... Hope this info helps some of the confusion and doesn't create more! Ralph |
