doozer's Avatar
Talking Front Suspension Travel - 2 up 2 down 18.0 Deg. motion.
Can it be true that the the 911 only has 2" of upward suspension travel at 0.0 Deg. angle on the A-arms?
Should there not be 3" of upper compression travel and 2" of rebounding travel giving a total of 22.5 Deg. ?
This is what I got:
@ 0" of travel : A-arm @ +9.0 Deg. ( Strut full compression )
@ 2" of travel : A-arm @ 0.0 Deg. ( A-arm level )
@ 3" of travel : A-arm @ -4.5 Deg.
@ 4" of travel : A-arm @ -9.0 Deg.
@ 7" of travel : A-arm @ -22.5 Deg. ( Strut full extension )
At 3" of upper compression travel the A-arm is @ -4.5 Deg. <<< Is this correct ride height?
DETAILS:
http://hypertec.ws/todd_porsche/photos/front_suspension/front_suspension.html
Todd
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 01-29-2005, 11:00 AM
Insane Dutchman
2 inches of jounce sounds low, but there are a number of things I would wonder about....any rubber bump stops in the shocks, I found there was only about 1/2 inch of jounce in my 911 (wore out a set of tires in one track day due to the understeer that it caused), discovered too long bump stops inside my Bilstiens....
Not sure what I got for travel, but 2 inches measured at the wheel centre sounds low...
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 01-29-2005, 11:07 AM
doozer's Avatar
Sorry I shoud have said a minimum of 2" jounce.
There is a total of 7" of front suspension travle to work with. The people who I have talked to who design suspensions say a minimum of 3" up and 2" down relative to ride height.
This was measured with the one OEM bumpstop in the BOGE, it compressed is about an inch in height.
Todd
Todd
Old 01-29-2005, 11:27 AM
PorscheGuy79's Avatar
I vote for 7" of travel and an entry into Dakar 2005.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 01-29-2005, 11:38 AM
doozer's Avatar
Ok, I saw another post where the factory angle was around -10.0 Deg.
This would equate to 4.00" of upward suspension travle before the strut bottomed out.
The only problem is with this much (4") upward travel I would have 2.75" of gap between the top of the front tire and the fender lip - this is with the OEM bump stop installed in the strut. Ekkk.
I also found 4.25" from torsion centerline to spindle centerline. I will compare this also.
Todd
Old 01-29-2005, 12:34 PM
