-   -   How To Get CHT Wire to Engine (http://forums.pelicanparts.com/porsche-911-technical-forum/203727-how-get-cht-wire-engine.html)
North Coast Cab 01-29-2005 08:57 AM
Is there an easy way? I don;t see any openings at all.
John
89turbocabmike 01-29-2005 09:06 AM
Hey John, do you mean from the passenger compartment? If so, I have an LM1 setup and found a large grommet in the driver side rear passenger footwell. A few inches up the rear vertical wall(just about where a passenger's heels would be. Nicely shielded from the elements.
Carrera3.5L 01-29-2005 10:22 AM
Re: How To Get CHT Wire to Engine
John
John, you should be able to run the cht sensor wire on #3 right along with the two flywheel sensors. They all mount together on the bracket off the left intake plenum. The backside should look something like this:
http://forums.pelicanparts.com/uploa...1107022863.jpg
Hope that helps a bit.
Ralph
Early_S_Man 01-29-2005 11:47 AM
John,
Along the tunnel under the carpet and into tunnel at coupler access cover ... out with the speedo wires and along the top of the transaxle.
Hopefully the cable that came with the gauge and thermocouple probe are long enough, because it is very important to use the same type of [J, K] thermocouple wire all the way from gauge to probe! If the cable isn't long enough ... there are extension cables available from Omega, Aircraft Spruce, etc.
rcaradimos 01-29-2005 11:50 AM
I would run from engine up, install new sensor, (important) cut old wire at base of old sensor, tape new wire to that and gently pull conector end of sensor up thru engine, clip male / female together.
If that makes sense.
Early_S_Man 01-29-2005 11:56 AM
rc,
I think John is asking about a CHT gauge installation, not replacement of the old NTC resistor sensor for a DME.
rcaradimos 01-29-2005 12:15 PM
Sorry, I just jumped right in, I was spinning off the pic post.
North Coast Cab 01-29-2005 12:28 PM
It is a CHT gauge installation. I have my carpet out so I have a clear shot back to the engine. I purchased the extension wire so I have plenty of length. I just don't see a good access spot. There are a few grommits, but they are old and hard and on top of the tranny.
John
Carrera3.5L 01-29-2005 12:45 PM
John
Sorry John, by your topic title I thought it was the wiring of the head temp sensor. My bad.
Ralph
