a911's Avatar
no electricity
Im having too much time as is winter here so i decided that fan should be litlle more cleaner. So i start cleaning it, and after while it starts shining. But that was difficult as housing and fan are in the car.
Then i took fan and housing apart and give it to painter to do red/black combo.
When all finished, i start to put things together. I marked wires to altenator, to not mess things up later. So im sure i put everything together as it was.
Today i did some other work and decide to start car. But no luck. No single light came on after turning key. Nothing. No clicking sound.... Checked batery and its fine since is almost new. Checked fuses in engine compartment and in lugage comp. and all fuses looks good.
So where to look. I just hope i didnt do too much damage. It looks like no electricity as turn key on. Did i blow some general fuse? Got bentley manual but didnt find anything that i could do.
Is it time to get some electrical specialist or can i do on my own?
"88" carrera
"02" tt roadster (wife) sold
"04" jaguar x-type
"04" kawasaki zx10r
"05" yamaha mayesty
"05" A3 sportback
Old 02-01-2005, 09:31 AM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
no power when the key is turned on usually means dead battery, or a bad connection to the battery. I doubt it has something to do with the alternator. It could be other things like ignition switch but I'd double check the battery and its connections first.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 02-01-2005, 09:57 AM
a911's Avatar
Does it have main fuse for all electricity? I didnt run car for a 3 weeks. I also in that time found ampfiler original in the passanger site under foot panel. Didnt disconect any wires yet, but could it be that i short circuit something that all electricity is gone?
"88" carrera
"04" jaguar x-type
"04" kawasaki zx10r
"05" yamaha mayesty
"05" A3 sportback
Old 02-01-2005, 10:15 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Are you sure you connected the alternator correctly? There is a connection between the battery and the alternator. What if you connected the B+ wire to the wrong terminal on the alternator.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 02-01-2005, 10:34 AM
