Brett's Avatar
confused...?
I pulled out of a carpark in my '78 SC and it cut out. The engine turns over when i turn the key, and i can smell unburnt fuel from the exhaust. The coil, distributor cap, rotor arm, leads and plugs were changed over a month ago. When i put the ignition on i get the high pitched whistle from the engine compartment.
I dont know whether to connect a positive to the coil as i heard somewhere that the SC has 2 earths on the coil and no direct positive??
No spark at all though - any ideas please??
Old 02-01-2005, 01:12 PM
What is a carpark? And what is "2 earths on the coil".
What I heard you say was that your fuel pump is working, but you are not getting spark. Is that correct?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 02-01-2005, 01:16 PM
Friend of Warren
Carpark = parking lot.
earth = ground
Kurt V
Old 02-01-2005, 01:17 PM
Brett's Avatar
yes, no spark but have fuel.
Just stating that i started it, pulled off and drove for 30 yards and it cut out . . .
Old 02-01-2005, 01:18 PM
Brett's Avatar
can anyone help?
Old 02-01-2005, 01:27 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
well to start with what I would do is connect a spart plug directly to the coil, and ground the coil. Then crank the motor. Do you get anything? then work your way back from there.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-01-2005, 02:00 PM
Brett's Avatar
Getting no spark at all? I was told that the coil has 2 "grounds" rather than a live and a ground so i am reluctant to connect a direct live to it? any ideas?
Old 02-01-2005, 02:15 PM
Brett's Avatar
taken coil HT lead from distributor cap and got my wife to crank the engine whilst i held the lead near the engine - no spark at all?
Old 02-01-2005, 02:19 PM
Brett's Avatar
Using a well insulated pair of pliers!! sorry - i am not being clear. I was using an ht lead from the coil, on a spark plug - grounded to the engine
No spark.
Old 02-01-2005, 02:45 PM
the green cable that plugs into the distributor gets frayed right at the plug and the outer ground wrapping can contact the inner wire. so rule that out. the ignition unit on the left side of the engine can make the whining sound and have no spark, (if it's bosch. permatunes don't whine) so the sound only tells you that there is power to the unit. a spare test unit is helpful for a quick diagnosis. don't give power to the coil terminal or you risk damaging the ignition unit, if it's still good that is. pop the cap for the hell of it to be sure there's nothing obvious like a broken rotor.
206 637 4071
Old 02-01-2005, 02:49 PM
Brett's Avatar
The wire to the disributor is new, and the two connections inside are good on the distributor. The distributor is in good condition, as is the wiring. (It is a Bosch)
Old 02-01-2005, 02:52 PM
Early_S_Man's Avatar
Porsche Crest
Brett,
No matter what ANYONE tells you ... DON'T CONNECT +12 Volts to the 'A' terminal of the coil!!! Also, ...
Please read the following Bosch CDI document in its' entirety! The only difference between your 6-pin CDI and the 3-pin unit described is the magnetic triggering used.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-01-2005, 04:26 PM
Porsche Crest
Here are the rest of the story [image limit reached above] ...
Here is a simplified diagram of the CDI wiring:
Here is the thread with 6-pin Bosch CDI repair documentation:
6-pin SC/Turbo CDI unit repair documentation
Warren Hall, Jr.
Old 02-01-2005, 04:28 PM
Brett's Avatar
Thanks!!
Old 02-02-2005, 12:28 AM
