76 CV joints
Hi all
I've read through the archives and still have a question. My 76 911s started with the clunk which is well described as time to change out a cv joint. Anyway I pulled the wheels and to my dismay I couldn't figure out which side, let alone which one is in need of replacing. Is there some little trick to telling which one or side is bad? Thanks in advance Rob |
Have you tried lifting the rear off the gound and rocking the axel back and fourth with your hand, if recall you can feel the worn one
Al |
Believe me I've been doing a lot of that. I was thinking about putting the wheels back on with the jackstands inplace then let it turn a little in gear (running) to see if I can better locate the clunk
