kumma's Avatar
welding 2 fenders together?
I have a 73 fender thats shot at the rear and mounting areas. Finding one for under 600 bucks has been a pain, as the midwest isnt a renowned Porsche parts area. I might as well go with fiberglass for that price. I wondering if its possible to weld the turn signal box on a 74 and up fender or are there other issues that would make this tough. Newer fenders are readily available it seems.
Old 01-28-2005, 02:37 PM
Glasgow 911SC's Avatar
This is definately possible. Backdaters have used this method.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 01-28-2005, 02:45 PM
if i convert my 77 930 to a RSR look, i'll be welding the front t/s sections on. i saved them from a 69 912 i parted out. so it's certainly doable.
206 637 4071
Old 01-28-2005, 02:47 PM
Didn't Milt (Zeke) do something similar? I think I recall him mentioning this recently.
Warren & Ron, may you rest in Peace.
Old 01-28-2005, 02:55 PM
Somewhere in the Midwest
MotoSook's Avatar
It is very possible, and for my next backdate project, I will likely do that instead of waiting months to find useable steel fenders. Even the steel fenders I bought from California after giving up hope to go the Ultimate RUF CTR path had to be repaired.
I've got them sandblasted no and will finish the last of the welding this weekend.
The guys at 911 and Posrche World did the weld on method. You will find the article in the Ultimate Backdate Thread.
If you are interested in having this done, and you need a shop to do it, MotoMotions can do it for you. I have my tub stripped at the moment, so fitting fenders and early leadign edge prior to welding would be a snap.
Old 01-28-2005, 06:57 PM
konish's Avatar
Souk,
Just sold my house in San Diego...I have a wad of cash just burning a hole in my pocket...when is that low boost turbo ITB EFI system going to be available, you cad!
R/
Dustin
Old 01-28-2005, 08:45 PM
Zeke's Avatar
Yes, I welded two fenders together, but at a much different place and for a much different reason. It certainly can be done.
Old 01-28-2005, 09:20 PM
The used fender I obtained had damage to the turn signal area. The old fender was perfect in that area so I cut out the bad on the new and welded in the good from the old. Not the best shots, but you get the idea.
Old 01-29-2005, 06:46 AM
Senior Member
Remember that the areas where you weld will lose their rust preventative coating, so when putting it all back together pay special attention to this and protect them. Do not want them rusting out a second time!
JoeA
Old 01-29-2005, 06:54 AM
We VW guys have been doing this for years. Here's a VW bus door that I sectioned.
Old 01-29-2005, 08:08 AM
kumma's Avatar
zeke- i knew i saw that on here just couldnt remember who did it. that section you cut out is where my fender is shot as well. the previous owner rivited sheet metal over bondo and then bondo'd again. the fender had a nice dome to it.
Old 01-29-2005, 08:34 AM
Zeke's Avatar
Like this abortion? I almost quit on the car when I found this.
It just got worse, I should have quit. But, it's all done and behind me now.
Old 01-29-2005, 01:12 PM
kumma's Avatar
yep that looks very familiar, except mine is the 7-11 super big gulp variety. im guessing both previous owners must of been related.
Old 01-29-2005, 07:41 PM
These pics illustrate the need for a replacement panel for the rearmost edge of front fenders. Seems to me Stoddard or someone made these years ago, but I haven't seen 'em anywhere in a long time other than a recent post about someone in PA or thereabouts making a repair piece, but just the bottom 6in or so. Anyone know of a repair for the entire rear edge? Sounds like money to be made for replacement panel business.
Old 01-30-2005, 10:47 AM
Here's the link to the place making lower edge panels.
www.alfaparts.net
Old 01-30-2005, 10:55 AM
I would rather be driving
jpnovak's Avatar
Here is two fenders I recently spliced together for a 67 912. The vertical section was rusted on one and the front section was rusted on another. Make two into one.
Pictures can be found here.
http://www.912bbs.org/index.php?a=thread&p=82519
First, align and tack the two sections. There is about 1 inch overlap here.
Next, cut up to the first tack with the saw and but weld after the cut. The overlapping section of metal is peeled out from behind.
Finish welding the seam and grind out.
Finish out with less than 1/16" filler to smooth seam. Paint and move on.
Best of luck.
Old 01-30-2005, 11:23 AM
Morrie's Avatar
Jamie is da man. You can see my amateur bodywork but not Jamie's seam. If I hadn't stupidly been trying to catch an experienced driver in an ST replica with tires 3x as wide as mine, I wouldn't have gotten myself into this mess in the first place!
Thanks again Jamie!
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 01-31-2005, 08:39 AM
Limbo
Slider79SC's Avatar
I have a set of fenders from an early (69) norrow car that we are adding steel 9 inch flares to convert it to an RSR. I will snap some pics and post them here for everyone once they are done.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 01-31-2005, 10:34 AM
