wastintime's Avatar
Send a message via AIM to wastintime
changing 964 springs B&A pics
Hey everyone,
I was going through some pics and realized I had some I'd meant to post months ago and forgot about. I had just wanted to post some gratuitous before and after pics, so here they are:
here's the initial rideheight
here's some pics of changing them out...
man those brakes fill up the wheels
here's a pic of the final rideheight... looks better than the one in taken in the same spot, sorry.
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 02-02-2005, 06:58 PM
Brother's Avatar
Very nice.
For all the crap people give 964's, I've always liked them.
Where in Charleston is Rennsport located?
Only fifteen more years until I get to live there.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 02-02-2005, 08:27 PM
what is the deal with your rubber lip on your RSA tail, did you change them out. if so how easy was it?
Old 02-03-2005, 07:38 PM
wastintime's Avatar
Rennsport is in West Ashley, right near Citadel Mall if you know where that is.
Ah the tail... In theory it's very easy to change them out... the only problem is that the RSA tail is shaped differently than the earlier Carrera tails believe it or not and has a different part number... so the turbo rubber does not fit perfectly, there is a small lip on the bottom where the rubber meets the fiberglass, but it doesn't seem to affect the performance. Also, the earlier rubbers used a different bolt pattern, so you have to drill two holes in the fiberglass.
However, the neat thing about it is that you can customize your rear downforce for the track you are on. The RSA rubber can be used when you want to go really fast on the straights and downforce isn't an issue, it's my low drag configuration. Next you can use a 965 Turbo rubber which made the same overall downforce on the rear axles of a 965 as the earlier rubber did on 930s, but since the 965s were aerodynamically cleaner, it made less drag. Then Theres the rubber pictured which is the high drag, really high downforce configuration which is the rubber element from a 930.
So, changing them out isn't bad... it just infuriates me to no end that they don't fit perfectly.
-Andy
Old 02-03-2005, 10:07 PM
Elombard's Avatar
Are those the stock shocks with threaded adjusters? I think that is how they came factory, very cool.... does the regulare C2 have that?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-04-2005, 05:10 AM
