Reer widsheild rust!!!
ive got some bad rust right under my reer widsheild and im havin trouble on how to deel wit it. if u have any info on it pls tell me cuz i dont want to make this peice.
Spell check?
Yikes -
i know, was just in a hurry
I assume you have the window out?? then take a wire wheel and clean the puss out......if there is metal left,, POR it....if no metal weld in a pc..Maybe mom here sells the corners?? I know they sell the fronts
i see
Norm
I think AWOL is just having some fun with all of us as well as asking a serious question...imho Cheers Brian |
Weather permitting I will be doing some of the semi-final cutting up of a 68 coupe this weekend, glass comes out and roof is coming off, let me know if you need replacement pieces such as where or send me a pic of yours so I'll know how much extra to leave. Cutting some special orders for some others off this same car.
AWOL-
I have the same problem. I was able to buy a replacement panel from EASY in CA from a donor car. New panels are not available. It's a lot of work drilling out all of the spot welds in order to remove the old panel and install the replacement, but it's the right way to do it. -Scott |
thanks and ill post some pics later
Pretty common rust area. If it's surface only, clean it up and POR it.
If more substantial 1) cut http://www.elephantracing.com/images...rnercutout.jpg 2) weld http://www.elephantracing.com/images...ays/tacked.jpg 3) grind http://www.elephantracing.com/images...shedcorner.jpg This corner require almost zero fill. |
thanks ill use thoes pics
AWOL,
Just a side note, you may want to edit your location in the "user CP"; and just list a city instead of your actual address. Post pics of the project as it progresses. |
| All times are GMT -8. The time now is 05:34 PM. |
