-   -   Valve guides replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/204477-valve-guides-replacement.html)
marineblue911 02-03-2005 06:49 AM
Hi folks,
My 87 Carrera is burning quite abit of oil but my plugs are clean. So I guess my valve guides need replacing pronto.
Appreciate if anyone can help me with a list of items I would need as part of the valve guides replacement job.
My guess would be:
1. Valve guides
2. Cam cover gaskets
3. maybe exhaust valves?
4. ??
Thks!
john walker's workshop 02-03-2005 07:00 AM
the intake valve stems are usually quite worn, if you take a mic to them. intake, exhaust gaskets, valve cover kit, tuneup parts, oil, filters, cam lines maybe, check the clutch, for a few things.
Hendog 02-03-2005 01:06 PM
Are you new to the 911? I am, and what I thought was a lot of oil being burnt was actually normal oil consumption. Could that be the case?
toolman 02-03-2005 01:19 PM
How much oil do you use per ??? miles.
Hendog 02-03-2005 01:21 PM
I've used about 1.5 litres in about 8000 Km (5000 miles).
john walker's workshop 02-03-2005 01:57 PM
when it gets to a quart in 300-500 miles, it's probably time. a crusty oil fouled plug in one hole gives you a clue too.
