930 A-arms on early car ?
Apart from the sway bar mounts, are there any differences between the A-arms from an '83 Turbo model & those fitted to '69-'73 models ?
If there are differences, can the Turbo A-arms (& alloy front crossmember) be fitted to the earlier cars ?
Any advantages/disadvantages ?
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 02-10-2005, 02:26 AM
AFAIK, the only difference between the turbo front susp. and regular is the hub, so the a-arms, struts, dampers etc. should all be the same...
WWW.9GEAR.NL
Old 02-10-2005, 05:03 AM
klaucke's Avatar
I saw a post yesterday where Tyson (TRE Cup) said the 930 front trailing arms are mounted slightly differently, with the rearward mount slightly higher, to help provide some anti-dive geometry on the heavier 930's. Perhaps they will still fit, I'm not sure, but it's something to consider.
I want to say that the struts had something slightly different also, the latter style being safer.
Old 02-10-2005, 06:24 AM
beepbeep's Avatar
930 rear sway arms are completly different/shorter. 930 front A-arms should be the same, except for hubs.
Thank you for your time,
Old 02-10-2005, 06:26 AM
DW SD's Avatar
"I saw a post yesterday where Tyson (TRE Cup) said the 930 front trailing arms are mounted slightly differently, with the rearward mount slightly higher, to help provide some anti-dive geometry on the heavier 930's. Perhaps they will still fit, I'm not sure, but it's something to consider.
I saw that, too. My impression of Tyson's comments was the pickup point was slightly changed in the rear of the front a-arm. So the geometry is different relative to the car, but the a-arm itself was the same. Hopefully, Tyson will clarify.
1971 RSR - interpretation
Old 02-10-2005, 06:30 AM
beepbeep's Avatar
hmm...I never heard anything about "front trailing arms"?
There are trainling arms in the rear and they are completly different. Length, hubs, pickup-points, geometery...everything is different, apparantly to reduce squat.
Thingies in front are usually called "A-arms" (as they look as letter "A") and they should be completly similar, except for turbo having solid plastic tie-rods and different hubs (to accept bigger brakes).
Old 02-10-2005, 06:38 AM
DW SD:
I think your presumption is correct. The altered location of the rear support ( of the front A-arm) offers a small degree of anti-dive for the 930...but the A-arm itself should work. I'd be mighty surprised if this is wrong.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Super Moderator
cstreit's Avatar
DWSD. Tyson posts as Tyson. TRE Cup is Dave B.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-10-2005, 08:03 AM
