Elombard's Avatar
fuel accumulator ?
I took the bottom line loose from my accumulator last night and turned the fuel pump on. fuel poured out. My understanding is that this would indicate the diaphrgm is leaking. Is that right?
My car is doing the CIS surge but my research did not reveal that a bad accumulator would cause this???
ANy way I have searched the archives and seen that leaking accumulators are bad but ususally they did not have the pump on when they get the leak. Wanted to check before spending money.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-29-2004, 08:49 AM
IROC's Avatar
I have always assumed this meant the diaphragm was leaking. Mine did this and I replaced it and it didn't do it any more. :>)
A bad accumulator will also show up as a hard starting when warm problem. Cranks and cranks until it starts kinda thing.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-29-2004, 09:30 AM
ASD ASD is online now
ASD's Avatar
I need a little clarity on this one.
I am supposed to start the engine to charge up the injection system, then shut it down, and pull the line off the bottom of the accumulator. Then if it drips its shot. Right?
Also do you put a wrench on one of the top lines to hold the acc from turning while you pull off the bottom line?
I have a hot start problem I am trying to chase. (78 911sc) Thanks
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 02-09-2005, 07:38 AM
Elombard's Avatar
Yes to your first question.
There is a little squared off area on the fuel acc. that you put your wrench on.
Old 02-09-2005, 09:35 AM
ASD's Avatar
Ok I didn't see any squared off area to put a wrench on, but I held the thing steady and pulled the bottom line off. It did drip.
So I guess this is the hot start problem I have had. ?? If so I know what I need to buy now. Thanks
Old 02-09-2005, 04:31 PM
Elombard's Avatar
DOnt get too excited, mine was totally shot and I did not have any hot start problems.... YOu can by pass it if you can figure out how to plug all of the hoses and run for a while like that to make sure its your problem.
Old 02-09-2005, 04:35 PM
Hot start problem can be check valve.
'80 SC
Old 02-09-2005, 06:19 PM
Who is John Galt?
Rondinone's Avatar
Hot start problems can also be leaking injectors. Surging can be a maladjusted WUR. You should spend $50 to get a fuel pressure gauge, as that's less than any CIS part costs, and you will know for sure what the problem is.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 02-09-2005, 06:52 PM
Where's a good place to pick up a fuel pressure guage?
Dave
'75 911s Coupe
Old 02-10-2005, 09:57 PM
Elombard's Avatar
Pelican sells them. I bought a cheapo and the fittings from an Aeroquip store. ~$70. For a few more bucks you can get the real deal from Pelican (If I had known :-))
Old 02-11-2005, 04:05 AM
MAGA
Tim Hancock's Avatar
They are pretty easy to make too if you have the right kind of stuff laying around.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-11-2005, 05:44 AM
