NOH20's Avatar
Where does this line connect to??
Ignore the lines pointing to the rubber hoses, I borrowed this photo from another post. I'm confused as to where the small braided line needs to go that is connected to the back of the throttle body. Mine is connected to the back of the throttle body as shown however, the other end is laying in the engine bay on the LH side. Where does it go and what is it's function?
2001 Twin Turbo
Old 02-05-2005, 11:06 AM
NOH20's Avatar
bump
2001 Twin Turbo
Old 02-05-2005, 05:21 PM
kqw kqw is offline
I believe that that hose connects to the ambient air valve located above the oil filler neck...
The Fox
Carrera
Old 02-05-2005, 06:26 PM
NOH20's Avatar
KQW,
Does it connect to the top of the AAV, or the bottom??
2001 Twin Turbo
Old 02-05-2005, 06:40 PM
kqw kqw is offline
It connects to the TOP of the AAV.
The Fox
Carrera
Old 02-05-2005, 06:45 PM
NOH20's Avatar
Thanks, I'll take a look at it tomorrow. Any reason why there is no diagram (PET) or the like, that shows this line connected to the top of the AAV?? I can't seem to find one.
2001 Twin Turbo
Old 02-05-2005, 06:49 PM
kqw kqw is offline
Loaned my doc's and bentley to a friend so I cannot look it up. However, I suspect it would be under Vac. lines, throttle body etc....
The Fox
Carrera
Old 02-05-2005, 06:56 PM
