Roll bar mounting points
I have just purchased a used das sport type bolt in roll bar where do you bolt in the back legs ? I have not taken the carpet or rear seats out yet so I can not see any mounting points any help ?
Thanks Again Steven |
Mine has four holes 1/2" in diameter the front bars screw into the seatbelt mounts the back holes are perpindicular to the seats so they must bolt in to the frame somewhere .
See the big honkin' flat head screw that holds the rear seat backs? That is where it bolts.
BTW, Good luck getting said big honkin' flat head screw out. Tom |
Thanks for the help I happen to have a b.f.s. that will work in getting out the screw.Thanks for the help.
| All times are GMT -8. The time now is 03:09 PM. |
