Wandered off somewhere...
Drdogface's Avatar
Question Legal Exhaust changes
Living here in the Peoples Republic of Kalifornia we're always threatened by the BAR (Smog Nazis) so I figger I better ask before doing any exhaust changes.
My 78 SC passed smog easily last November. I would like to go to SSI's and perhaps a higher flow muffler and Cat if I can still pass. As far as I know my system is stock.
Experts...can I get away with this...if so what besides the SSI's can/should I consider.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 02-04-2005, 10:00 AM
Send a message via AIM to eurocarrera
I'm not an SC expert, but with my Carrera, I think I am going to have to replace my CAT the next time I bring it in for smog.
After speaking with some of the people who run the smog stations, and then a representative from one of the referee stations (I wanted to just call and complain - just for the heck of it), it appears the biggest issue is the NO output which has to be between something like 1000 - 1500 PPM. The ONLY way I hear of to reduce that figure is to actually have a 3-way CAT on the car. So, all I do is put the stuff back on the car every two years like several other people do as well just to make it pass. This may be able to be acomplished via advancing or retarding of the timing, but like I said I am not an SC expert. ANyone have a 5 way gas analyzer????
Bill Atkins
mrpeabody37@yahoo.com
1985 Carrera Coupe ROW - SOLD
Old 02-04-2005, 10:08 AM
tiorio's Avatar
You can get away with the headers and the exhaust. The CAT is a problem. Here's a quote from the CA DMV site:
Catalytic Converters
A legal aftermarket catalyst is one that is listed in an ARB approved manufacturers catalogue for the year, make, model, and engine size of vehicle on which it is being installed. Manufacturers of aftermarket catalytic converters must obtain an Executive Order for their products from the Air Resources Board in order to be listed in an approved catalogue.
So you need a CA legal CAT for your exact car. Don't know what's available but I'm sure a little additional research will reveal what (if anything) is available.
-Todd
'89 930, '97 TLC (Toyota Land Cruiser), '96 T-100pick-em-up
'95 BMW R100 GSPD (gone but not forgotten), '07 BMW R1200GSA
Old 02-04-2005, 12:45 PM
Formerly bb80sc
Vipergrün's Avatar
You only need the cat for the visual. Proof: I passed smog on my SC with a gutted cat I had to lean the heck out ot the mixture, to the point she would barely idle, but she passed.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-04-2005, 04:45 PM
I'm not positive but I believe that the SSI's are not compatible with a cat. You may pass the emissions but fail the visual.
Old 02-04-2005, 05:07 PM
randywebb's Avatar
only need the cat for the visual....
The problem is that they don't (yet) do a cold start test. The car may pass the regualr test when it is warm but will pollute like crazy until it warms up w/o a cat on it. You may not care, but there is a reason for the stringent regs. -- people are dying from air pollution every day and you are contributing to that. Not to mention the other resource damage being done.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-04-2005, 05:38 PM
Drdogface's Avatar
Randy,
Thanks for your input. BTW, I didn't say I wanted to remove the cat...just get a more modern one w/o all the flow restriction if such is available. Pls don't assume I don't care !!
Mark...
Porsche Boxster S
Old 02-04-2005, 05:54 PM
randywebb's Avatar
OK.
BTW, The ones PAG uses on its new cars are supposed to be very free-flowing. Not sure what to do re an older engine.
Old 02-04-2005, 06:12 PM
It is my understanding that a catalizer only starts working properly when it is warmed-up. I don't know how they'll ever be able to do cold start tests on older cars... Most of them would just fail miserably.
88 BMW 325
86 911 Turbo
Old 02-04-2005, 08:57 PM
randywebb's Avatar
Ah, that's where the fast warm up cats on the newer cars come in.
Old 02-04-2005, 10:09 PM
Diss Member
Quicksilver's Avatar
The kids at the test only station that I take my car to wouldn't recognize a 'visual' difference if I put a Cosworth DFV in the car. Just make sure there is a good quality CAT in there.
Someone listed an extremely good performance CAT yesterday. I'll see if I can find it.
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-05-2005, 06:26 AM
Diss Member
Found it. Here is the vendor link that I liked a lot:
http://www.randomtechnology.com/technical.html
The thread that it came off of is here:
sport cat, free-flowing cat
Wayne
Old 02-05-2005, 06:33 AM
yogi's Avatar
I sent an email about the Lenz powerkat. They sent me back saying it's a direct bolt in and comes with gaskets, bolts and the bunge for the o2. The price is steep at $850.
I called random and they said their cat is around $250. They would need information to make it for the Porsche. They need to know overall length, where the bunge for the o2 is placed, and the diameter of the in and out pipe. I'm not sure how to describe the in pipe to them. They do not have dyno runs to compare on the porsche. In almost all instances there is a power increase in using their cat over a stock cat. If someone can supply them with the info they need I know I would be interested in one. From what I've read you want the metal core cat.
Jerry Baer
87 Carrera Coupe
Old 02-05-2005, 07:12 AM
randywebb's Avatar
Will the fuel system automatically adjust for a lower flow cat?
I'd want to know before putting one on.... Good luck.
Old 02-05-2005, 11:38 AM
sjp_30188's Avatar
Send a message via AIM to sjp_30188
Beware the visual inspection of the cat. I left the cat off and just went to the inspection station in Georgia with a straight pipe. I watched the guy, he bent down, looked at the muffler, checked "yes" on the visual cat question, and tested the car. Still failed NO without the cat, had to put it back on, but I got quite a chuckle
Steve Phillips
87 Carrera
"Thanks Kay!"
Old 02-05-2005, 12:29 PM
randywebb's Avatar
In some states if you fail certain inspections - e.g. non-std. equip. - they put you on a special list, and you will get special attention....
Luckily, Asscroft is no longer Atty. Genl, tho....
Old 02-05-2005, 03:09 PM
