911FL's Avatar
license plate lights
My lights on the rear license plate have stopped working. I have checked the fuse, the bulbs and connections and all seems well. The only thing left is the ground. The Bentley book only says ground in engine compartment...but where? Any help here would be appreciated.
Dan
“Out on some Sonoma County road, with Jimmy Dean and Steve McQueen”
1984 Carrera Targa
Old 02-05-2005, 11:00 AM
PMB Performance
Eric_Shea's Avatar
Check under your hinge on the drivers side. There should be a ground strap there (between the hinge and the deck lid)
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-05-2005, 11:02 AM
CMXI-SC's Avatar
Lightbulb
Just a thought. Have you had any transmission work done receintly? There is a connector for the lic. lights high up on the passenger side of the trans. Hard to get to. May have been left disconnected.
Jack
Old 02-05-2005, 11:23 AM
911FL's Avatar
No luck there. Thanks anyway. I may just live with it and hope the cops don't use this as an excuse to pull me over...
Dan
1984 Carrera Targa
Old 02-05-2005, 12:05 PM
PMB Performance
Eric_Shea's Avatar
Ground on the drivers side wall of the engine compartment?
855-STOP-101
Old 02-05-2005, 12:06 PM
911FL's Avatar
I made the mistake (?) of cleaning the underside of the engine with a hose recently (see other post on oil leak) and sounds like I may have knocked off the connector perhaps. I will have to check that, but you mentioned it's difficult to get to. Can it be felt blindly and reconnected if loose?
Dan
1984 Carrera Targa
Old 02-05-2005, 01:12 PM
Slant83cab's Avatar
Talking tag light problems
Hi..I had the same problem. It was the ground wires on the driver side wheelwell. When I removed the lights and jiggled them they worked. I traced it to the wiring as it runs behind the rear bumber and up the driver rear wheelwell. No problems fixed
Rick..Parkland, FL
1983 slantnose cabrio
2005 Carrera 997
2003 Mercedes E500 sport
2004 Lexus RX330
Old 02-05-2005, 04:49 PM
creaturecat's Avatar
ground the light out on something - quickest way to troubleshoot
Old 02-05-2005, 04:53 PM
